1 amp fuse in left front frame rail blows.i am going to change lid check switch as it appears to blow when door opens.do you think if that does not resolve issue it could be water supply manifold causing short?
Groups: Expert
Could be the check switch or primary lid switch, not the water inlet valves.
Eric
