My GE hydrowave washer will fill then click like it wants to work, but will not agitate. It will also drain and try to spin. It at first did not have any blinking light, so I replaced the harness fuse. It blew again. I have checked several things with the ohm meter. It's leading me back to the the fuse. Help please!
There could be a problem with the motor/inverter assembly but change out the fuse again. If it still blows you may have to change out the motor/inverter just to see if that fixes things. If you buy from this site and son't need the part you can return it.
