Discuss
kenmore 500 washer
 in
Washer Repair
my kenmore washer wont fill up with water, it stops between, and when it does throw water its hot. the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore 500 washer
  #1 (permalink)
Old 10-25-2014, 12:40 PM
Junior Member
dvazquez is on a distinguished road
Unhappy kenmore 500 washer
Brand: Kenmore   Age: 1 - 5 years
my kenmore washer wont fill up with water, it stops between, and when it does throw water its hot. the cold or warm water dont work, everything else works fine the spin cycle works.. its only the water problems... please help asap!!! 😒😡
  #2 (permalink)
Old 10-25-2014, 12:59 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Disconnect hoses from washer, direct cold water hose into tub and turn wall valve on to make sure cold water flow is ok. Check for clogged screens inside the water valve inlets at back of washer and any screens in the hose ends. If all good, we need the washer model number to be of any further help.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore washer searay Washer Repair 3 06-20-2014 01:50 PM
Kenmore washer rayjay4 Washer Repair 3 01-26-2011 06:06 AM
kenmore washer-installing clips for the top of the washer donnadean Washer Repair 1 02-17-2010 11:49 AM
Kenmore elite washer is leaking under washer cbs Washer Repair 1 07-12-2009 06:27 PM
Kenmore Washer nlwpmf2 Washer Repair 1 05-05-2009 02:55 PM
