Discuss
Whirlpool (unknown model) currently filled/wont start
 in
Washer Repair
My mother is having issues with her washer and I'm at a loss of what to do here. It is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool (unknown model) currently filled/wont start
  #1 (permalink)
Old 10-22-2014, 03:14 PM
Junior Member
g_host3519 is on a distinguished road
Default Whirlpool (unknown model) currently filled/wont start
Brand: Whirlpool   Age: Less than 1 year
My mother is having issues with her washer and I'm at a loss of what to do here. It is currently filled with water. After it filled up, it stopped due to something with her electricity. Were not sure what the problem with the outlet is, but we ran an extension cord from a tested and working outlet to the washer and it still will not turn on. She has messed with the knobs since it stopped so I'm not sure if that has something to do with it. I will post a picture of the washer below since I don't know the model number. Keep in mind it is currently filled with water and I'm unsure how to drain it. Can't do too much as far as looking at the back to find a model number. Any help/suggestions would be appreciated.
Sorry for my complete lack of actual description. I'm not that great with repairs like this, just trying to help her out. Hoping it is a simple fix.
EDIT- Can't upload a picture. Doesn't work the same way as other forums Ive been on.
EDIT again - I should add that since I dont have the model number it is a bit older. Standard white washing machine, top loading, no LED lights or digital displays. Pretty simple. Knobs for load size, water temp, and then the actual wash cycle desired.
  #2 (permalink)
Old 10-22-2014, 04:25 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Model number is probably under lid somewhere. What if you place timer directly to drain/spin with lid closed? Doesn't work there either? You can drain by removing drain hose from standpipe, placing end into bucket and lower both together.
Eric
  #3 (permalink)
Old 10-23-2014, 05:29 PM
Junior Member
Default
Back with the model number. Also drained the machine with a hose so I can get to the back. Still not getting power from an outlet I know is working.
Model number lsr7300pq1
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Delayed start after water filled Remegia Washer Repair 3 05-12-2014 01:09 PM
Whirlpool Duet filled with water when door is open clothdiapermom Washer Repair 2 06-26-2013 05:06 PM
Whirlpool washer filled up then stopped bosadi Washer Repair 1 08-31-2011 06:30 PM
Whirlpool duet wont start when start button is pushed happymom Washer Repair 1 02-02-2011 07:28 AM
Unknown Model Number--My Oven Won't Heat CoolCalm Oven Repair (including Ranges and Cooktops) 0 02-06-2009 12:39 PM
