Discuss
Kenmore Front Loader
 in
Washer Repair
Kenmore front loader is having issues. I have power, hit the start button the door locks, but water does not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Front Loader
  #1 (permalink)
Old 10-09-2014, 09:11 AM
Junior Member
mbrown7776 is on a distinguished road
Default Kenmore Front Loader
Model Number: 41744152400   Brand: Kenmore   Age: 5 - 10 years
I have power, hit the start button the door locks, but water does not start.
In diag mode I can get it to do everything except the 1st and 3rd tests completely (I think those are both cold water and bleach/soap dispenser things).
Is this a control board issue, water dispenser/valve, or the bleach/soap dispenser issue?
I think the control board had been replaced about 7 years ago when we first got the unit and it was under warrenty.
Thanks,
Matt
Related Models
Kenmore 41744152400 WASHER
Kenmore 41744152401 WASHER
Kenmore 41744152500 WASHER
Kenmore 41744252500 WASHER
Kenmore 41744252501 WASHER
Kenmore 41747102700 WASHER
Kenmore 41747102701 WASHER
Kenmore 41748102700 WASHER
Kenmore 41748102701 WASHER
Kenmore 41748106700 WASHER
Kenmore 41748112700 WASHER
Kenmore 41748112701 WASHER
Kenmore 41748116700 WASHER
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Kenmore 41759012890 GAS DRYER
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41759022890 GAS DRYER
Kenmore 41764182300 ELECTRIC DRYER
Kenmore 41769042990 KENMORE DRYER
Kenmore 41769042991 DRYER
Kenmore 41769052990 DRYER
Kenmore 41769052991 ELECTRIC DRYER
Kenmore 41774182300 GAS DRYER
Kenmore 41774182301 GAS DRYER
Kenmore 41779042990 DRYER
Kenmore 41779042991 DRYER
Kenmore 41779052990 DRYER
Kenmore 41779052991 DRYER
Kenmore 41780032990 DRYER
Kenmore 41780042990 DRYER
Kenmore 41780042991 DRYER
Kenmore 41780052990 DRYER
Kenmore 41780052991 DRYER
Kenmore 41780142000 DRYER
Kenmore 41780412700 DRYER
Kenmore 41781042000 DRYER
Kenmore 41781042001 DRYER
Kenmore 41781052000 ELECTRIC DRYER
Kenmore 41781052001 DRYER
Kenmore 41781100000 DRYER
Kenmore 41781101000 DRYER
Kenmore 41781102000 DRYER
Kenmore 41781142000 DRYER
Kenmore 41781142001 DRYER
Kenmore 41782042100 DRYER
Kenmore 41782042101 DRYER
Kenmore 41782042102 SEARS/DRYER
Kenmore 41782052100 DRYER
Kenmore 41782052101 DRYER
Kenmore 41782052102 DRYER
Kenmore 41782052103 SEARS/ELECTRIC DRYER
Kenmore 41782142100 DRYER
Kenmore 41782142101 DRYER
Kenmore 41782142102 SEARS/ELECTRIC DRYER
Kenmore 41783042200 SEARS/DRYER
Kenmore 41783042201 SEARS/ELECTRIC DRYER
Kenmore 41783042300 DRYER
Kenmore 41783052200 SEARS/DRYER
Kenmore 41783052201 SEARS/DRYER
Kenmore 41783142200 SEARS/DRYER
Kenmore 41783142201 SEARS/ELECTRIC DRYER
Kenmore 41783142300 DRYER
Kenmore 41784042500 DRYER
Kenmore 41784052500 DRYER
Kenmore 41784072300 DRYER
Kenmore 41784082500 DRYER
Kenmore 41784092500 DRYER
Kenmore 41784130000 DRYER
Kenmore 41784131000 DRYER
Kenmore 41784132000 DRYER
Kenmore 41784152500 DRYER
Kenmore 41784252500 DRYER
Kenmore 41784988100 AUTOMATIC WASHER
Kenmore 41784988800 AUTOMATIC WASHER
Kenmore 41787042700 DRYER
Kenmore 41788042700 DRYER
Kenmore 41788052700 DRYER
Kenmore 41788056700 DRYER
Kenmore 41788076700 DRYER
Kenmore 41788988100 ELECTRIC DRYER
Kenmore 41788988800 ELECTRIC DRYER
Kenmore 41788989100 GAS DRYER
Kenmore 41788989800 GAS DRYER
Kenmore 41789090100 WASHER DRYER COMBINATION
Kenmore 41789090110 COMBINATION WASHER-DRYER
Kenmore 41789090200 WASHER DRYER COMBINATION
Kenmore 41789090210 COMBINATION WASHER-DRYER
Kenmore 41789090400 WASHER DRYER COMBINATION
Kenmore 41789090410 COMBINATION WASHER-DRYER
Kenmore 41789090600 WASHER DRYER COMBINATION
Kenmore 41789090610 COMBINATION WASHER-DRYER
Kenmore 41789090800 WASHER DRYER COMBINATION
Kenmore 41789090810 COMBINATION WASHER-DRYER
Kenmore 41789190100 COMBINATION WASHER/DRYER
Kenmore 41789190110 COMBINATION WASHER/DRYER
Kenmore 41789190120 COMBINATION WASHER/DRYER
Kenmore 41789190600 COMBINATION WASHER/DRYER
Kenmore 41789190610 COMBINATION WASHER/DRYER
Kenmore 41789190620 COMBINATION WASHER/DRYER
Kenmore 41789190800 COMBINATION WASHER/DRYER
Kenmore 41789190810 COMBINATION WASHER/DRYER
Kenmore 41789190820 COMBINATION WASHER/DRYER
Kenmore 41789195100 COMBINATION WASHER/DRYER
Kenmore 41789195110 COMBINATION WASHER/DRYER
Kenmore 41789195120 COMBINATION WASHER/DRYER
Kenmore 41789195600 COMBINATION WASHER/DRYER
Kenmore 41789195610 COMBINATION WASHER/DRYER
Kenmore 41789195620 COMBINATION WASHER/DRYER
Kenmore 41789195800 COMBINATION WASHER/DRYER
Kenmore 41789195810 COMBINATION WASHER/DRYER
Kenmore 41789195820 COMBINATION WASHER/DRYER
Kenmore 41789390100 COMBINATION WASHER/DRYER
Kenmore 41789390101 COMB, WASHER/DRYER
Kenmore 41789390110 COMBINATION WASHER/DRYER
Kenmore 41789390600 COMBINATION WASHER/DRYER
Kenmore 41789390700 COMBINATION WASHER/DRYER
Kenmore 41789390701 COMB, WASHER/DRYER
Kenmore 41789390710 COMBINATION WASHER/DRYER
  #2 (permalink)
Old 10-10-2014, 06:21 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
I doubt if it is the water valve parts, most likely it is the control unit. But first check the connections and wiring between the door lock assembly and the control unit. If they are ok or reseating everything does not help try replacing the control unit. If you buy it from this site and it does not fix the problem you can return it.
__________________
  #3 (permalink)
Old 10-11-2014, 11:01 PM
Junior Member
Default
Thanks for the reply there looks to be two control units listed on this site.
I guess one says Control Board the other says Control-Electical do you know which one I should try? I think the one is the front panel the other is some place else (that I can't seem to find).
Thanks,
Matt
  #4 (permalink)
Old 10-12-2014, 06:49 AM
Senior Expert
APP Volunteer
Default
This is the one to try
Part number: AP4362527
You are right, there are two electronic control units. The other one is what Frigidaire terms a speed control board and it controls the motor. If often fails but it doesn't seem like your symptoms are from its failure, although if the main control unit replacement does not fix things that is the next thing to try.
Yes, we know this sounds like a primitive way to diagnose these problems, but that's often what you have to do in models that have electronics.
__________________
  #5 (permalink)
Old 10-15-2014, 08:35 AM
Junior Member
Default
That was it, took about 5 or 10 minutes to get it swapped out.
Washer is back in business now.
Thanks,
Matt
  #6 (permalink)
Old 10-15-2014, 11:18 AM
Senior Expert
APP Volunteer
Default
Great glad that worked out and thanks for updating us.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore front loader mdfpenguin Washer Repair 0 10-06-2012 12:27 PM
Kenmore front loader batesville Washer Repair 3 02-15-2010 07:19 AM
kenmore front loader fell onto front while moving. ohhhden Washer Repair 1 01-26-2010 08:22 PM
Kenmore front-loader codkat Washer Repair 1 03-31-2009 08:26 AM
Kenmore eco front loader lagger619 Washer Repair 1 12-03-2008 02:12 PM
