Discuss
No high speed spin - E58
 in
Washer Repair
Slow alternating spins ok, but no fast spin in any cycle/mode. Getting E58. Followed tech sheet thru diagnostics and performed
Appliance Repair Forum > Appliance Repair Help > Washer Repair » No high speed spin - E58
  #1 (permalink)
Old 10-05-2014, 07:25 PM
Junior Member
bobw462 is on a distinguished road
Thumbs down No high speed spin - E58
Model Number: FAFS4247LW0   Brand: Frigidaire   Age: 1 - 5 years
Followed tech sheet thru diagnostics and performed Test 8. Motor and drum spin freely. Motor pins 1-2, 2-3, 1-3 all between 3.9 -4.5. Pins 4-5 at 122. Drain sump and hoses clear. Pump seems fine. Changed motor controller - no fix. Changed door lock/switch - no fix.
Is there any way to test the main control board output and/or the level switch? I really don't want to just keep throwing parts at it.
Any suggestions for a next move? Thanks.
Related Models
Frigidaire FAFS4272LA0 WASHER
Frigidaire FAFS4272LN0 WASHER
Frigidaire FAFS4272LR0 WASHER
Frigidaire FAFS4272LW0 WASHER
Frigidaire FAFS4473LA0 WASHER
Frigidaire FAFS4473LN0 WASHER
Frigidaire FAFS4473LR0 WASHER
Frigidaire FAFS4473LW0 WASHER
Frigidaire FAFS4474LA0 WASHER
Frigidaire FAFS4474LN0 WASHER
Frigidaire FAFS4474LR0 WASHER
Frigidaire FAFS4474LW0 WASHER
Frigidaire FAFW3511KB0 WASHER
Frigidaire FAFW3511KR0 WASHER
Frigidaire FAFW3511KW0 WASHER
Frigidaire FAFW3511KW1 WASHER
Frigidaire FAFW3514KA0 WASHER
Frigidaire FAFW3514KA1 WASHER
Frigidaire FAFW3514KN0 WASHER
Frigidaire FAFW3514KN1 WASHER
Frigidaire FAFW3517KA1 WASHER
Frigidaire FAFW3517KB0 WASHER
Frigidaire FAFW3517KB1 WASHER
Frigidaire FAFW3517KN0 WASHER
Frigidaire FAFW3517KN1 WASHER
Frigidaire FAFW3517KR0 WASHER
Frigidaire FAFW3517KR1 WASHER
Frigidaire FAFW3517KT1 WASHER
Frigidaire FAFW3517KW0 WASHER
Frigidaire FAFW3517KW1 WASHER
Frigidaire FAFW3574KA0 FRONT LOAD WASHER
Frigidaire FAFW3574KB0 FRONT LOAD WASHER
Frigidaire FAFW3574KN0 FRONT LOAD WASHER
Frigidaire FAFW3574KR0 WASHER
Frigidaire FAFW3574KW0 FRONT LOAD WASHER
Frigidaire FAFW3577KA0 WASHER
Frigidaire FAFW3577KA1 WASHER
Frigidaire FAFW3577KB0 WASHER
Frigidaire FAFW3577KB1 WASHER
Frigidaire FAFW3577KN0 WASHER
Frigidaire FAFW3577KN1 WASHER
Frigidaire FAFW3577KR0 WASHER
Frigidaire FAFW3577KR1 WASHER
Frigidaire FAFW3577KW0 WASHER
Frigidaire FAFW3577KW1 WASHER
Frigidaire FAFW3801LB0 WASHER
Frigidaire FAFW3801LW0 WASHER
Frigidaire FAFW4011LB0 WASHER
Frigidaire FAFW4011LW0 WASHER
Frigidaire FAFW4221LB0 WASHER
Frigidaire FAFW4221LW0 WASHER
Frigidaire FAH085N1T Frigidaire/air Conditioner
Frigidaire FAH085N1T2 Frigidaire/air Conditioner
Frigidaire FAH085P1T1 Frigidaire/air Conditioner
Frigidaire FAH086J1T1 Frg/room Air Conditioner
Frigidaire FAH086J1T2 Frg/room Air Conditioner
Frigidaire FAH086M1T1 Frigidaire/air Conditioner
Frigidaire FAH086N1T1 Frigidaire/air Conditioner
Frigidaire FAH086R1T1 Frigidaire/air Conditioner
Frigidaire FAH086S1TA ROOM AIR CONDITIONER
Frigidaire FAH086S1TA11 ROOM AIR CONDITIONER
Frigidaire FAH086S1TA12 ROOM AIR CONDITIONER
Frigidaire FAH086S1TA13 ROOM AIR CONDITIONER
Frigidaire FAH086S1TB ROOM AIR CONDITIONER
Frigidaire FAH086T1T0 ROOM AIR CONDITIONER
Frigidaire FAH086T1T10 ROOM AIR CONDITIONER
Frigidaire FAH08EJ1T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH08EM1T1 Frigidaire/air Conditioner
Frigidaire FAH08EN1T Frigidaire/air Conditioner
Frigidaire FAH08EN1T2 Frigidaire/air Conditioner
Frigidaire FAH08EN1T3 Frigidaire/air Conditioner
Frigidaire FAH08EP1T1 Frigidaire/air Conditioner
Frigidaire FAH08ER1T1 Frigidaire/air Conditioner
Frigidaire FAH08ES1TA ROOM AIR CONDITIONER
Frigidaire FAH08ES1TA11 ROOM AIR CONDITIONER
Frigidaire FAH08ES1TA12 ROOM AIR CONDITIONER
Frigidaire FAH08ES1TA13 ROOM AIR CONDITIONER
Frigidaire FAH08ES1TB ROOM AIR CONDITIONER
Frigidaire FAH08ET1T0 ROOM AIR CONDITIONER
Frigidaire FAH08ET1T10 ROOM AIR CONDITIONER
Frigidaire FAH096J2T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH096J2T2 Frg(v0) / Room Air Conditioner
Frigidaire FAH096J2T3 Frigidaire/air Conditioner
Frigidaire FAH096M2T1 Frigidaire/air Conditioner
Frigidaire FAH105N1T Frigidaire/air Conditioner
Frigidaire FAH105N1T2 Frigidaire/air Conditioner
Frigidaire FAH105N2T Frigidaire/air Conditioner
Frigidaire FAH105N2T2 Frigidaire/air Conditioner
Frigidaire FAH105P1T1 Frigidaire/air Conditioner
Frigidaire FAH105P2T1 Frigidaire/air Conditioner
Frigidaire FAH106J1T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH106J1T2 Frigidaire/air Conditioner
Frigidaire FAH106J2T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH106J2T2 Frigidaire/air Conditioner
Frigidaire FAH106M1T1 Frigidaire/air Conditioner
Frigidaire FAH106M2T1 Frigidaire/air Conditioner
Frigidaire FAH106N1T1 Frigidaire/air Conditioner
Frigidaire FAH106N2T1 Frigidaire/air Conditioner
Frigidaire FAH106R1T1 Frigidaire/air Conditioner
Frigidaire FAH106R2T1 Frigidaire/air Conditioner
Frigidaire FAH106S1TA ROOM AIR CONDITIONER
Frigidaire FAH106S1TA11 ROOM AIR CONDITIONER
Frigidaire FAH106S1TA12 ROOM AIR CONDITIONER
Frigidaire FAH106S1TA13 ROOM AIR CONDITIONER
Frigidaire FAH106S1TB ROOM AIR CONDITIONER
Frigidaire FAH106S2TA ROOM AIR CONDITIONER
Frigidaire FAH106S2TA11 ROOM AIR CONDITIONER
Frigidaire FAH106S2TA12 ROOM AIR CONDITIONER
Frigidaire FAH106S2TA13 ROOM AIR CONDITIONER
Frigidaire FAH106S2TB ROOM AIR CONDITIONER
Frigidaire FAH106T1T0 ROOM AIR CONDITIONER
Frigidaire FAH106T1T10 ROOM AIR CONDITIONER
Frigidaire FAH106T2T0 ROOM AIR CONDITIONER
Frigidaire FAH106T2T10 ROOM AIR CONDITIONER
Frigidaire FAH10EJ2T2 Frigidaire/air Conditioner
Frigidaire FAH10EM2T1 Frigidaire/air Conditioner
Frigidaire FAH10EN2T Frigidaire/air Conditioner
Frigidaire FAH10EN2T2 Frigidaire/air Conditioner
Frigidaire FAH10EN2T3 Frigidaire/air Conditioner
Frigidaire FAH10EP2T1 Frigidaire/air Conditioner
  #2 (permalink)
Old 10-13-2014, 04:25 PM
Junior Member
Thumbs up Update-Success!
Update... I removed motor intending to replace it. Noticed a lot of black carbon dust on motor frame and underside of tub/cabinet. Usually, this indicates that motor brushes are wearing. Since I would need to wait on the new motor anyway, I tried an old trick... firmly tapped around the motor housing hoping to free and reseat the worn brushes, and also blew out most of the carbon dust with compressed air.
Reinstalled motor, and it spun up just like new!
Not sure which of my repairs/replacements was the actual fix. But, it is working again...for now.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No high speed spin Motorat Washer Repair 2 09-15-2013 08:50 AM
No High Speed Spin johngotts Washer Repair 0 01-14-2013 09:58 AM
no high speed spin jaceo Washer Repair 0 06-07-2012 11:48 AM
GE 2 speed washer won't spin in high speed buzzybucks Washer Repair 1 12-16-2011 05:53 PM
No high speed spin surferfletch Washer Repair 1 01-15-2010 05:27 PM
