Discuss
Control board or Motor (Hall Sensor)
 in
Washer Repair
Hello Problem started with a OE alarm. Washer would fill for a long time until the level reached to approx
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Control board or Motor (Hall Sensor)
  #1 (permalink)
Old 10-03-2014, 08:49 PM
Junior Member
Matina is on a distinguished road
Default Control board or Motor (Hall Sensor)
Model Number: MAH9700AWM   Brand: Maytag   Age: 5 - 10 years
Hello
Problem started with a OE alarm. Washer would fill for a long time until the level reached to approx half way up the viewing door. OE alarm would appear and the washer would drain to empty again. Changed the pressure switch and still having the same problem. New pressure switch reads ~2.5V pink to orange and purple to orange. ~24ohms across pink to purple. Service mode shows ~26kHz empty and ~21Khz when water is at its highest point before it goes into alarm and starts to drain.
Also noticed that there is a humming/buzz coming from the motor that I never really heard before. Started to troubleshoot with a Quick Spin Test and noticed that the drum would not turn. Tested the board output and the drum still would not turn.
After turning the power on/off a couple times the noise went away. Tried the Quick Spin Test and received an 3E error. Tried the board output again and received 3E error again.
After repeating the test a few times I observed that whenever there is that low humming from the motor the drum does not turn during the spin test or board output test with no error code. If the hum is not there the same test gives a 3E code FWIW??
Unplugged CN9 and tested the wires on the harness:
Red - White ~ 12Ω
White - Blue ~ 12Ω
Red - Blue ~ 12Ω
Unplugged CN8 and tested the wires on the harness:
Orange - all = infinite resistance
Blue to Pink = infinite resistance
Red to Pink = infinite resistance
Red to Blue = infinite resistance
Would I need to replace the motor, the board or both? Also not sure if the 3E is what caused the overfill and drain condition that started it all.
Any help would be appreciated.
Related Models
Maytag MAH9700AWM WASHER- HORIZONTAL AXIS
Maytag MAH9700AWQ WASHER- HORIZONTAL AXIS
Maytag MAH9700AWW WASHER- HORIZONTAL AXIS
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM MISC / ACCESSORY
Maytag MAL1800AXQ MISC / ACCESSORY
Maytag MAL1800AXW MISC / ACCESSORY
Maytag MAL2000AXQ MISC / ACCESSORY
Maytag MAL2000AXW MISC / ACCESSORY
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL MANUAL, PARTS (WASHER)
Maytag MAT10CSAAW MANUAL, PARTS (WASHER)
Maytag MAT10CSAGL MANUAL, PARTS (WASHER)
Maytag MAT10CSAGW MANUAL, PARTS (WASHER)
Maytag MAT10CSEGL MANUAL, PARTS (WASHER)
Maytag MAT10CSEGW MANUAL, PARTS (WASHER)
Maytag MAT10DAAAL MANUAL, PARTS (WASHER)
Maytag MAT10DAAAW MANUAL, PARTS (WASHER)
Maytag MAT10DAABL MANUAL, PARTS (WASHER)
Maytag MAT10DAABW MANUAL, PARTS (WASHER)
Maytag MAT10PDAAL MANUAL, PARTS (WASHER)
Maytag MAT10PDAAW MANUAL, PARTS (WASHER)
Maytag MAT10PDABL MANUAL, PARTS (WASHER)
Maytag MAT10PDABW MANUAL, PARTS (WASHER)
Maytag MAT10PDEGW MAYTAG LAUNDRY (COMM.EXPORT) (WASHER)
Maytag MAT10PSAAL MANUAL, PARTS (WASHER)
Maytag MAT10PSAAW MANUAL, PARTS (WASHER)
Maytag MAT10PSAGL MANUAL, PARTS (WASHER)
Maytag MAT10PSAGW MANUAL, PARTS (WASHER)
Maytag MAT11CSBKL MANUAL, PARTS (WASHER)
Maytag MAT11MNAAW MANUAL, PARTS (WASHER)
Maytag MAT11MNAGW MANUAL, PARTS (WASHER)
Maytag MAT11MNEGW MANUAL, PARTS (WASHER)
Maytag MAT11PDAAL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDAAW MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABW MAYTAG LAUNDRY (WASHER)
Maytag MAT12CSAAL MANUAL, PARTS (WASHER)
Maytag MAT12CSAAQ MANUAL, PARTS (WASHER)
Maytag MAT12CSAAW MANUAL, PARTS (WASHER)
Maytag MAT12CSAGW MANUAL, PARTS (WASHER)
Maytag MAT12CSAKL MANUAL, PARTS (WASHER)
Maytag MAT12CSAKQ MANUAL, PARTS (WASHER)
Maytag MAT12CSDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSEGW MANUAL, PARTS (WASHER)
Maytag MAT12CSFWQ COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSFWW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLGW MAYTAG COMMERCIAL WASHER (WASHER)
Maytag MAT12CSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDAAL MANUAL, PARTS (WASHER)
Maytag MAT12PDAAW MANUAL, PARTS (WASHER)
Maytag MAT12PDABL MANUAL, PARTS (WASHER)
Maytag MAT12PDABW MANUAL, PARTS (WASHER)
Maytag MAT12PDAGW MANUAL, PARTS (WASHER)
Maytag MAT12PDBAL MANUAL, PARTS (WASHER)
Maytag MAT12PDBAQ MANUAL, PARTS (WASHER)
Maytag MAT12PDBAW MANUAL, PARTS (WASHER)
Maytag MAT12PDBBL MANUAL, PARTS (WASHER)
Maytag MAT12PDBBQ WASHER-TOP LOADING
Maytag MAT12PDBBW MANUAL, PARTS (WASHER)
Maytag MAT12PDCBL MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDBW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDEGW MANUAL, PARTS (WASHER)
Maytag MAT12PDLAQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLAW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLGW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDSAW MANUAL,PARTS (WASHER)
Maytag MAT12PRAAW MANUAL, PARTS (WASHER)
Maytag MAT12PRAEW MANUAL, PARTS (WASHER)
Maytag MAT12PRBAW MANUAL, PARTS (WASHER)
Maytag MAT12PRDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PRSAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAGW MANUAL, PARTS (WASHER)
Maytag MAT12PSBAW MANUAL, PARTS (WASHER)
Maytag MAT12PSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT13MNAAW MANUAL, PARTS (WASHER)
Maytag MAT13MNAGW MANUAL, PARTS (WASHER)
Maytag MAT13MNDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNEGW MANUAL, PARTS (WASHER)
Maytag MAT13PDAAW MANUAL, PARTS (WASHER)
Maytag MAT13PDBAW MANUAL, PARTS (WASHER)
Maytag MAT13PNAEW MAYTAG LAUNDRY (WASHER)
Maytag MAT13PNDEW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13PRBWW MAYTAG LAUNDRY (WASHER)
Maytag MAT14CSAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14CSAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14CSBGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14PDAWW0 COMMERCIAL AUTOMATIC WASHER
Whirlpool MAT14PDAXW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14PRAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT15MNAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT15MNAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT15MNBGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT23PCAAG MANUAL, PARTS (WASHER)
Maytag MAT23PCAAL MANUAL, PARTS (WASHER)
Maytag MAT23PCAAW MANUAL, PARTS (WASHER)
Maytag MAT23PCABG MANUAL, PARTS (WASHER)
Maytag MAT23PCABL MANUAL, PARTS (WASHER)
Maytag MAT23PCABW MANUAL, PARTS (WASHER)
Maytag MAT25CSAAG MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSAAL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSAAW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSAGG MAYTAG LAUNDRY (EXPORT) (WASHER)
Maytag MAT25CSAGL MAYTAG LAUNDRY (EXPORT) (WASHER)
Maytag MAT25CSAGW MAYTAG LAUNDRY (EXPORT) (WASHER)
Maytag MAT25CSBIL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSCAG MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT25CSCAL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE F3 Error - replaced sensor and control board Ares Oven Repair (including Ranges and Cooktops) 0 04-17-2011 11:20 AM
Replacing a Control Board and Sensor Kit for GE Refrigerator thomike23 Refrigerator & Freezer Repair 0 08-31-2010 04:33 PM
Maytag Washer will not spin. How do you bench test the hall effect sensor on the mot electrotec Washer Repair 1 12-24-2009 09:53 AM
Oven will not hold temp! Already tried Control Board & Sensor! Now what??? NicCar99 Oven Repair (including Ranges and Cooktops) 1 12-03-2008 09:15 PM
temp sensor or oven control board? Mike523 Oven Repair (including Ranges and Cooktops) 1 12-17-2007 08:29 PM
