I am having a couple of intermittent strange probelems with this GE Profile Harmony 9350 washer;
A. Sometimes it powers up, after you select the wash mode, it goes to the "load sensing" screen and just sits there timing down, no a movement at all. Sometimes after 5-10 minutes it will take off, agitating and filling with water. Sometimes I can power down the washer, let it sit for a few minutes and power it back up and most times it will work fine,
B. Sometimes after beginning the wash cycle, the washer completely shuts down without draining. You have to power it back up and run a drain and spin cycle.
6 months ago I replaced the clutch mechanism which was broke, the motor and the sensor. It ran fine for a month or so and then these newest problems cropped up.
Any help would be much appreciated.
