Discuss
Brake on whirlpool washer
 in
Washer Repair
I was trying to replace a belt on this washer and inadvertantly loosened the set screw on the upper Drum
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Brake on whirlpool washer
  #1 (permalink)
Old 10-25-2009, 10:34 AM
mechanic mechanic is offline
Junior Member
mechanic is on a distinguished road
Default Brake on whirlpool washer
Model Number: LA7685XPW1   Brand: Whirlpool   Age: More than 10 years
I was trying to replace a belt on this washer and inadvertantly loosened the set screw on the upper Drum brake which allowed the springs to extend, is there a correct proceedure for bringing this brake back to its correct position so I can retighten this set screw?
Thank you in advance for your help.
Related Models
Whirlpool LA7685XPW1
Whirlpool LA7685XPW2
Whirlpool LA7700XPW0
Whirlpool LA7700XPW1
Whirlpool LA7700XPW3
Whirlpool LA7700XPW4
Whirlpool LA7700XPW5
Whirlpool LA7700XSW0
Whirlpool LA7700XWN0
Whirlpool LA7700XWW0
Whirlpool LA7780XSW0
Whirlpool LA7780XSW1
Whirlpool LA7780XSW2
Maytag LA7800 Washer - Top Loading
Whirlpool LA7800XKW0
Whirlpool LA7800XKW1
Whirlpool LA7800XKW2
Whirlpool LA7800XMW0
Whirlpool LA7800XPW0
Whirlpool LA7800XPW1
Whirlpool LA7800XSW0
Whirlpool LA7800XSW1
Whirlpool LA7800XSW2
Whirlpool LA7800XTF0
Whirlpool LA7800XTF1
Whirlpool LA7800XTG0
Whirlpool LA7800XTG1
Whirlpool LA7800XTM0
Whirlpool LA7800XTM1
Whirlpool LA7800XTN0
Whirlpool LA7800XTN1
Whirlpool LA7800XTW0
Whirlpool LA7800XTW1
Whirlpool LA7801XTF0
Whirlpool LA7801XTG0
Whirlpool LA7801XTM0
Whirlpool LA7801XTN0
Whirlpool LA7801XTW0
Whirlpool LA7805XKW0
Whirlpool LA7805XKW1
Whirlpool LA7899XPW3
Whirlpool LA7900XPW1
Whirlpool LA7900XSW0
Whirlpool LA7900XSW1
Whirlpool LA7900XSW2
Whirlpool LA7900XTF0
Whirlpool LA7900XTG0
Whirlpool LA7900XTG1
Whirlpool LA7900XTM0
Whirlpool LA7900XTN0
Whirlpool LA7900XTN1
Whirlpool LA7900XTW0
Whirlpool LA7900XTW1
Whirlpool LA7980XSW0
Frigidaire LA800AXD1 Wwh(v2) / 27 " Washer
Frigidaire LA800AXD2 Wwh(v2) / 27 " Washer
Frigidaire LA800AXW1 Wwh(v1) / 27 " Washer
Frigidaire LA800AXW2 Wwh(v1) / 27 " Washer
Frigidaire LA800JXD4 Wwh(v1) / Washer
Frigidaire LA800JXD5 Wwh(v1) / Top Load Washer
Frigidaire LA800JXF4 Wwh(v2) / Washer
Frigidaire LA800JXH4 Wwh(v3) / Washer
Frigidaire LA800JXH5 Wwh(v2) / Top Load Washer
Frigidaire LA800JXV4 Wwh(v4) / Washer
Frigidaire LA800JXW4 Wwh(v5) / Washer
Frigidaire LA800JXW5 Wwh(v3) / Top Load Washer
Frigidaire LA800MXD1 Wwh(v9) / 27 " Washer
Frigidaire LA800MXD2 Wwh(v9) / 27 " Washer
Frigidaire LA800MXH1 Wwh(v8) / 27 " Washer
Frigidaire LA800MXH2 Wwh(v8) / 27 " Washer
Frigidaire LA800MXW1 Wwh(v7) / 27 " Washer
Frigidaire LA800MXW2 Wwh(v7) / 27 " Washer
Maytag LA806 Washer - Top Loading
Maytag LA806S Washer - Top Loading
Maytag LA810 Washer - Top Loading
Maytag LA8100 Washer - Top Loading
Whirlpool LA8100XWW0
Whirlpool LA8100XWW1
Maytag LA8120 Washer - Top Loading
Maytag LA8140 Washer - Top Loading
Maytag LA8200 Washer - Top Loading
Whirlpool LA8200XWW0
Whirlpool LA8200XWW1
Maytag LA8210 Washer - Top Loading
Maytag LA8240 Washer - Top Loading
Maytag LA8340 Washer - Top Loading
Amana LA83830.A Mwave - Family Size (60 Hz)
Whirlpool LA8400XWF0
Whirlpool LA8400XWF1
Whirlpool LA8400XWG0
Whirlpool LA8400XWG1
Whirlpool LA8400XWM0
Whirlpool LA8400XWM1
Whirlpool LA8400XWN0
Whirlpool LA8400XWN1
Whirlpool LA8400XWW0
Whirlpool LA8400XWW1
Maytag LA8420 Washer - Top Loading
Maytag LA8440 Washer - Top Loading
Maytag LA8500 Washer - Top Loading
Maytag LA8520 Washer - Top Loading
Whirlpool LA8580XWF0
Whirlpool LA8580XWF1
Whirlpool LA8580XWF2
Whirlpool LA8580XWG0
Whirlpool LA8580XWG1
Whirlpool LA8580XWG2
Whirlpool LA8580XWM0
Whirlpool LA8580XWM1
Whirlpool LA8580XWM2
Whirlpool LA8580XWN0
Whirlpool LA8580XWN1
Whirlpool LA8580XWN2
Whirlpool LA8580XWW0
Whirlpool LA8580XWW1
Whirlpool LA8580XWW2
Maytag LA8600 Washer - Top Loading
Maytag LA8640 Washer - Top Loading
Maytag LA8650 Washer - Top Loading
Maytag LA8700 Washer - Top Loading
  #2 (permalink)
Old 10-26-2009, 09:34 AM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
This is a pretty old belt driven Whirlpool that unfortunately we almost never work on. There is a service manual for this machine that you can buy but I did not see your issue addressed in it. Here it is.
Part number: AP3884815
if you want to get it. Maybe someone else can post the info you need.
__________________
  #3 (permalink)
Old 10-26-2009, 04:53 PM
Junior Member
Default
Thank you for your help sidfink43, I have just ordered the manual. I have put the new belt in but as suspected it no longer has a spin cycle and I beleieve its because the brake is no longer gripping stong enough to spin the drum. If anyone else knows how to adjust this brake correctly please help, meanwhile I hope I can get some info from the manual. again thanks for the help.
  #4 (permalink)
Old 10-27-2009, 05:18 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
That setscrew goes in a hole in the spin tube. Only way to fix this is to remove the tranny, pull off spin basket and remove spin tube. You will need a vice to compress the brake housing to put back the set screw. Rather long and difficult job, but doable.
An easier way to fix this is to pry down the spin tube, pry up the brake housing, and allign the set screw with the hole in the spin tube. Then push up the spin tube, support the spin tube with boards, and have someone push down on the washer till the hole lines up with the set screw.
There is also another way to fix this. Turn the belt and pull up the spin solenoid till the slide bar drops down the brake. Squirt some oil on the brake, then move the belt till the slide bar pushes the brake up. Remove the set screw and turn the spin basket till the hole in the spin tube is visible in the set screw hole. Put back set screw, job is finished!!
I really doubt the repair manual would have this sort of info. Also, if you use light oil, or none at all on the brake, it should burn off after some time in use.
__________________
  #5 (permalink)
Old 10-27-2009, 05:24 AM
Senior Expert
APP Volunteer
Default
__________________
  #6 (permalink)
Old 10-27-2009, 05:33 PM
Junior Member
Default
richappy, thank you for your reply, I will try what you recomend this weekend and hope I can get the brake setscrew back were it belongs, and hope I get my spin cycle back. again thanks it is very much appreciated.
  #7 (permalink)
Old 11-01-2009, 02:07 PM
Junior Member
Default
richappy, thanks for the info on getting the setscrew back in wihtout taking the machine all apart, it worked like a charm! everything works now and spin cycle is good. couldnt have done it without your help. im glad that sidfink43 recommended the manual since it help me understand the operations of which selenoid control the spin cam. the book is good but doesnt go into any detail on reparing any major things like the brake issue you helped me with or tranny repair. anyway thanks alot it helped me out.
  #8 (permalink)
Old 11-01-2009, 02:21 PM
Senior Expert
APP Volunteer
Default
Great, kudos to richappy for that great explanation and to you for getting it done. Thanks for the update.
__________________
  #9 (permalink)
Old 11-02-2009, 02:33 AM
Senior Expert
APP Volunteer
Default
We are all glad you got this fixed, it is really a good feeling to get something fixed without a lot of grief/money.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool belt drive washer has brake noise when stopping macirion Washer Repair 0 08-08-2009 05:43 PM
Direct drive washer brake yurman Washer Repair 1 08-02-2009 05:35 AM
brake on atlantis washer mteal Washer Repair 0 01-25-2009 07:33 AM
Whirlpool brake or clutch issue mtreu Washer Repair 16 01-03-2009 10:24 AM
GE Washer brake scald Washer Repair 9 11-14-2008 05:56 AM
