Discuss
Maytag Performa filling in middle of wash cycle
 in
Washer Repair
I have an older Performa that is doing something weird. It will fill just fine, at any level and then
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Performa filling in middle of wash cycle
  #1 (permalink)
Old 09-22-2014, 05:04 PM
Junior Member
oZo61 is on a distinguished road
Default Maytag Performa filling in middle of wash cycle
Model Number: LAT2500AAE   Brand: Maytag   Age: More than 10 years
I have an older Performa that is doing something weird. It will fill just fine, at any level and then stop filling. Then the wash cycle starts, and all is well. That is until about half way through the wash cycle. Then it abruptly stops, and starts to fill again (already full) and overflows and just keeps going. If I manually stop it, and click it one notch, it will still fill. But if I click it two notches, then it begins to drain and run towards the rinse cycle. Neither rinse cycles overflow while filling, no matter what the level is set to.
There are no leaks anywhere inside the cabinet, I have checked.
Could it be the timer mechanism is bad? I have replaced it once, but that time the washer was just dead.
Any advice is appreciated!
**UPDATE***
I have found that I can stop the tub filling again by turning the "Infinite Water Level" knob fully counter-clockwise, to "Mini". After the wash cycle is done, and the water begins to drain, I turned the water level back to "Oversize" for the rinses. This leads me to believe it is either the water level switch (the actual mechanism behind the "Infinite Water Level" knob), or the Tub Air hose, that runs from the bottom of the outer tub to that same control.
Any thoughts?
Thanks!
Related Models
Maytag LAT2500AAE WASHER-TOP LOADING
Maytag LAT2600AAE WASHER-TOP LOADING
Maytag LAT2910AAL WASHER-TOP LOADING
Maytag LAT2910AAW WASHER-TOP LOADING
Maytag LAT2914AAE WASHER-TOP LOADING
Maytag LAT2914AAL WASHER-TOP LOADING
Maytag LAT2914AAM WASHER-TOP LOADING
Maytag LAT2915AAE WASHER-TOP LOADING
Maytag LAT2915AAM WASHER-TOP LOADING
Maytag LAT2916AAE WASHER-TOP LOADING
Maytag LAT2916AAM WASHER-TOP LOADING
Maytag LAT2916ABE WASHER-TOP LOADING
Maytag LAT3500AAE WASHER-TOP LOADING
Maytag LAT3500AAQ WASHER-TOP LOADING
Maytag LAT3600AAE WASHER-TOP LOADING
Maytag LAT3600AAQ WASHER-TOP LOADING
Maytag LAT3910AAL WASHER-TOP LOADING
Maytag LAT3910AAW WASHER-TOP LOADING
Maytag LAT3914AAE WASHER-TOP LOADING
Maytag LAT3914AAL WASHER-TOP LOADING
Maytag LAT3914AAM WASHER-TOP LOADING
Maytag LAT4000AAW WASHER-TOP LOADING
Maytag LAT4910AAL WASHER-TOP LOADING
Maytag LAT4910AAW WASHER-TOP LOADING
Maytag LAT4914AAE WASHER-TOP LOADING
Maytag LAT4914AAL WASHER-TOP LOADING
Maytag LAT4914AAM WASHER-TOP LOADING
Maytag LAT4915AAE WASHER-TOP LOADING
Maytag LAT4915AAM WASHER-TOP LOADING
Maytag LAT4916AAE WASHER-TOP LOADING
Maytag LAT4916AAM WASHER-TOP LOADING
Maytag LAT4916ABE WASHER-TOP LOADING
Maytag LAT5000AAL WASHER-TOP LOADING
Maytag LAT5000AAW WASHER-TOP LOADING
Maytag LAT5000ABL WASHER-TOP LOADING
Maytag LAT5000ABW WASHER-TOP LOADING
Maytag LAT5004AAW WASHER-TOP LOADING
Admiral LAT5004AGW WASHER-TOP LOADING
Admiral LAT5004BGW WASHER-TOP LOADING
Maytag LAT5005AAE WASHER-TOP LOADING
Maytag LAT5005AAW WASHER-TOP LOADING
Maytag LAT5005ABW WASHER-TOP LOADING
Maytag LAT5006AAE WASHER-TOP LOADING
Admiral LAT5006AGE WASHER-TOP LOADING
Admiral LAT5006GGE WASHER-TOP LOADING
Maytag LAT5910AAL WASHER-TOP LOADING
Maytag LAT5910AAW WASHER-TOP LOADING
Maytag LAT5910BAL WASHER-TOP LOADING
Maytag LAT5910BAW WASHER-TOP LOADING
Maytag LAT5914AAE WASHER-TOP LOADING
Maytag LAT5914AAL WASHER-TOP LOADING
Maytag LAT5914AAM WASHER-TOP LOADING
Maytag LAT5916AAE WASHER-TOP LOADING
Maytag LAT5916AAM WASHER-TOP LOADING
Maytag LAT5916ABE WASHER-TOP LOADING
Maytag LAT6910AAL WASHER-TOP LOADING
Maytag LAT6910AAW WASHER-TOP LOADING
Maytag LAT6914AAE WASHER-TOP LOADING
Maytag LAT6914AAL WASHER-TOP LOADING
Maytag LAT6914AAM WASHER-TOP LOADING
Maytag LAT7300AAL WASHER-TOP LOADING
Maytag LAT7300AAW WASHER-TOP LOADING
Maytag LAT7300ABL WASHER-TOP LOADING
Maytag LAT7300ABW WASHER-TOP LOADING
Maytag LAT7300ABX WASHER-TOP LOADING
Maytag LAT7300AGL WASHER-TOP LOADING
Maytag LAT7300AGW WASHER-TOP LOADING
Maytag LAT7300AGX WASHER-TOP LOADING
Maytag LAT7304AAE WASHER-TOP LOADING
Maytag LAT7304AAL WASHER-TOP LOADING
Maytag LAT7304AAM WASHER-TOP LOADING
Maytag LAT7304ABE WASHER-TOP LOADING
Maytag LAT7304ABL WASHER-TOP LOADING
Maytag LAT7304ABM WASHER-TOP LOADING
Admiral LAT7304AGE WASHER-TOP LOADING
Maytag LAT7304DAL WASHER-TOP LOADING
Maytag LAT7304EGE WASHER-TOP LOADING
Admiral LAT7304GGE WASHER-TOP LOADING
Maytag LAT7306AAE WASHER-TOP LOADING
Maytag LAT7314AAE WASHER-TOP LOADING
Maytag LAT7314AAL WASHER-TOP LOADING
Maytag LAT7314AAM WASHER-TOP LOADING
Maytag LAT7334AAE WASHER-TOP LOADING
Maytag LAT7334AAL WASHER-TOP LOADING
Maytag LAT7334AAM WASHER-TOP LOADING
Maytag LAT7334ABE WASHER-TOP LOADING
Maytag LAT7400AAL WASHER-TOP LOADING
Maytag LAT7400AAW WASHER-TOP LOADING
Maytag LAT7400ABL WASHER-TOP LOADING
Maytag LAT7400ABW WASHER-TOP LOADING
Maytag LAT7400ABX WASHER-TOP LOADING
Maytag LAT7480AAL WASHER-TOP LOADING
Maytag LAT7480AAW WASHER-TOP LOADING
Maytag LAT7480ABL WASHER-TOP LOADING
Maytag LAT7480ABW WASHER-TOP LOADING
Maytag LAT7500AAL WASHER-TOP LOADING
Maytag LAT7500AAW WASHER-TOP LOADING
Maytag LAT7500ABL WASHER-TOP LOADING
Maytag LAT7500ABW WASHER-TOP LOADING
Maytag LAT7500ABX WASHER-TOP LOADING
Maytag LAT7500AGL WASHER-TOP LOADING
Maytag LAT7500AGW WASHER-TOP LOADING
Maytag LAT7500AIL WASHER-TOP LOADING
Maytag LAT7500AIW WASHER-TOP LOADING
Maytag LAT7793AAL WASHER-TOP LOADING
Maytag LAT7793AAW WASHER-TOP LOADING
Maytag LAT7793ABL WASHER-TOP LOADING
Maytag LAT7793ABW WASHER-TOP LOADING
Maytag LAT7800AAL WASHER-TOP LOADING
Maytag LAT7800AAW WASHER-TOP LOADING
Maytag LAT7800ABL WASHER-TOP LOADING
Maytag LAT7800ABW WASHER-TOP LOADING
Maytag LAT7800ABX WASHER-TOP LOADING
Maytag LAT8004AAE WASHER-TOP LOADING
Maytag LAT8004AAL WASHER-TOP LOADING
Maytag LAT8004AAM WASHER-TOP LOADING
Maytag LAT8004ABE WASHER-TOP LOADING
Maytag LAT8005AAE WASHER-TOP LOADING
Maytag LAT8005AAM WASHER-TOP LOADING
Maytag LAT8006AAE WASHER-TOP LOADING
  #2 (permalink)
Old 09-24-2014, 08:42 PM
Junior Member
Default
Turns out it was the Air Tube after all. Problem solved.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Front load Washer shuts off in middle of wash cycle Dmjmam Washer Repair 3 08-05-2013 08:24 PM
washer keeps on filling, during the middle of the cycle wjcheng31 Washer Repair 0 04-25-2012 09:11 AM
Quit in middle of wash cycle wantoxcape Washer Repair 3 05-20-2010 05:06 PM
Maytag Performa Washer won't spin or wash on regular cycle gidy34 Washer Repair 1 11-14-2007 09:54 AM
washer stops in the middle of wash cycle cnic4 Washer Repair 1 10-20-2007 03:21 AM
