My 110.28002011 Kenmore washer originally had an error code of F5 E1, F7 E1, and F7 E7. I have already replaced the lock assembly and shift. Washer was calibrated and the first wash was ok, but a little wet. The second wash was wet and spent almost twice as long to run. Rechecking the error codes, F7 E1 is now showing again. I've checked the main board and it seems to be connected but I couldn't quite remove and reconnect so I'm not sure. What else can I do for my washer?
