Discuss
Kenmore 110: Won't Agitate. And no drain
 in
Washer Repair
This morning , the washer won't agitate. All I hear is a whining noise. Probably the transmission part of the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 110: Won't Agitate. And no drain
  #1 (permalink)
Old 09-21-2014, 11:32 AM
Member
jmrec100 is on a distinguished road
Default Kenmore 110: Won't Agitate. And no drain
Model Number: 110 92596100   Brand: Kenmore   Age: More than 10 years
This morning , the washer won't agitate. All I hear is a whining noise. Probably the transmission part of the washer. I am looking up the diagram now but I'd like some advice. It has always been a dynamite reliable machine with only a leak at the water pump several years back. I fixed that. But now no agitation. I replaced the agitator dogs about 3 years ago. Help where to start. I need to drain by hand since can't get it to drain either.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 09-21-2014, 12:12 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
May be something in the pump jamming the motor. Pull pump away from motor shaft and see if it will now agitate or spin. If good, remove pump hoses and check for obstruction inside pump.
Eric
  #3 (permalink)
Old 09-21-2014, 12:44 PM
Member
Default
I forgot where to get the diagrams of the assembly.
  #4 (permalink)
Old 09-21-2014, 01:13 PM
Expert
APP Volunteer
Default
Go to the Sears parts website and plug in your model number.
Eric
  #5 (permalink)
Old 09-21-2014, 02:40 PM
Member
Default
Thanks. I went to this parts site, looked up coupling for the motor. In there is a diagram of the assembly. Sears is also good. Thanks. Taking it apart now.
  #6 (permalink)
Old 09-21-2014, 06:31 PM
Member
Default
Having trouble getting that pump off. Seems have to break it. Thought I replaced the pump a few years ago. Must have a leak in it and rusted to the shaft. I get it about 1/4 of the way off then stuck. I'm spraying it with wd40, some auto spray for rusty bolts and see if I can get it off without breaking it. Probably need a new pump assembly?
  #7 (permalink)
Old 09-21-2014, 07:45 PM
Member
Default
I was able to take the pump with the motor off together as one piece. The coupling looks worn. The plastic on the coupling to the transmission to the barrel spin shaft ( not the motor side) is partially rounded. When I move the shaft from the transmission, the barrel spins- but only in one direction. I assume that is correct. Looks like the shaft on the trans may be somewhat round too. If it is, I'll tap a hole into the new coupling piece and set screw it to the shaft. $11 at Appliance Pros, $15.25 at Sears if in stock. May put in two at 90 degrees apart. As for the pump, It just isn't coming off 'nice'. So am I right guessing that the pump may have leaked some and should be replaced too. $30 at appliance pros. $43 at Sears.
  #8 (permalink)
Old 09-21-2014, 09:26 PM
Member
Default
Pump looks badly stuck. Can't pry it off without breaking it, so looks like new pump assembly.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore DD washer won't spin, does drain and agitate abitofathinker Washer Repair 5 01-28-2014 04:49 PM
Kenmore Washer won't spin, agitate or drain Micky_577 Washer Repair 3 05-14-2012 06:59 PM
Kenmore - NOT Agitate, Fill, Spin or Drain biledkid Washer Repair 3 02-03-2012 09:38 PM
Kenmore does not agitate, spin and drain Help_Please Washer Repair 3 10-24-2010 02:31 AM
kenmore won't agitate, spin, or drain tcatt11 Washer Repair 0 02-20-2008 10:54 AM
