b63826
#1 Posted : Sunday, October 25, 2009 8:12:31 AM(UTC)
b63826
front loading machine, close door, the locked door light comes on then the machine will just hum, no water.
sidfink43
#2 Posted : Monday, October 26, 2009 6:14:59 AM(UTC)
sidfink43
Unfortunately there are a lot of suspects here, and you will have to check out each one.
1. The water valve assembly is not working. even though it is getting 120v
2. Water level switch is bad.
3. The tube from the water level switch to the air bell is blocked, not likely but clean it out.
4. The door lock assembly is bad, and the machine will not start to fill because of this. This is your most likely problem.
Here is a service manual for a Frigidaire Gallery which is very similar to your machine. It should allow you to check out the above.
http://frigidaireservicetips.co..._TumbleActionWashers.pdf
Good luck.
Frigidaire washer will not fill. (Washer Repair)
by Elwood44 8/24/2021 12:55:10 PM(UTC)
Dishwasher Will Not Fill With Water (Dishwasher Repair)
by sfora71 10/7/2016 8:29:08 AM(UTC)
ge washer will not fill error code 10 (Washer Repair)
by Jimverbe 1/28/2016 7:58:07 PM(UTC)
Washer will not fill for Rinse Cycle (Washer Repair)
by KLS2015 6/28/2015 9:05:48 AM(UTC)
Maytag Washer will not fill (Washer Repair)
by creeves 12/28/2014 12:41:20 PM(UTC)
Whirlpool washer will not fill with water (Washer Repair)
by mdavis1218 1/17/2014 6:47:34 AM(UTC)
washer will not fill, only drain (Washer Repair)
by crodenburg 10/29/2013 1:46:23 PM(UTC)
Dishwasher will not fill (Dishwasher Repair)
by sultan62 4/9/2013 10:08:39 AM(UTC)
GE Washer will not fill (Washer Repair)
by Hock 3/31/2013 7:27:11 AM(UTC)
Kenmore 665.13893 Dishwasher Will Not Fill - New Water Inlet (Dishwasher Repair)
by ferant316 1/28/2013 3:18:58 PM(UTC)
by pbhall 1/17/2013 2:55:39 PM(UTC)
washer will not fill (Washer Repair)
by KarenSep 12/24/2012 1:23:59 PM(UTC)
Washer will not fill or wash (Washer Repair)
by rrobleto 11/1/2012 6:57:10 AM(UTC)
Whirlpool Top loading washer will not fill (Washer Repair)
by jeffjbrown 10/24/2012 6:43:26 PM(UTC)
by Annv 8/7/2012 6:18:45 AM(UTC)
