Good evening,
I just replaced the Rotor sensor on the machine and reassembled everything.
I thought I remembered the rotor being against the tub, but now, it appears that there is a small gap between the rotor and tub. All hardware is tight, but I am now hearing a rubbing sound as if the rotor is not on straight. Rotated it several times and it looks good.
I am concerned about the rubbing and the gap. Thoughts?
Thank you, DTJones369
