Discuss
Maytag stops mid cycle but timer at end
 in
Washer Repair
I have a SAV 2555 Maytag that doesn't complete the cycle every 2nd or 3rd time. The Timer goes to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag stops mid cycle but timer at end
  #1 (permalink)
Old 09-17-2014, 01:55 PM
Junior Member
CGMorris is on a distinguished road
Default Maytag stops mid cycle but timer at end
Model Number: SAV2555AWW   Brand: Maytag   Age: 5 - 10 years
I have a SAV 2555 Maytag that doesn't complete the cycle every 2nd or 3rd time. The Timer goes to the end but normally there is rinse water left in it. Everything is quiet - no motor running. So, you have to turn the timer to the rinse cycle and get it to empty and spin.
Today, it stopped at the end of the wash cycle so it had suds in it. When my wife went to get it to finish and spin, it did nothing. Couldn't even get it to start over. Then 10 min later we could set it to rinse and it finished it's cycle.
So whereas my first thought is the timer, I'm wondering if the pump motor has some sort of thermal relay that gets overheated. So, when we find it in this condition it has probably had time to cool off and it works again - except yesterday when we tried right after it finished.
Related Models
Maytag SAV2555AWW WASHER-TOP LOADING
Maytag SAV2655AWW WASHER-TOP LOADING
Maytag SAV3655AWW WASHER-TOP LOADING
Maytag SAV365AAWW WASHER-TOP LOADING
Maytag SAV365ZAWW WASHER-TOP LOADING
Maytag SAV3710AWW WASHER-TOP LOADING
Maytag SAV405DAWW WASHER-TOP LOADING
Maytag SAV405DEWW WASHER-TOP LOADING
Maytag SAV4655AWQ WASHER-TOP LOADING
Maytag SAV4655AWW WASHER-TOP LOADING
Maytag SAV4655EWQ WASHER-TOP LOADING
Maytag SAV4655EWW WASHER-TOP LOADING
Maytag SAV4710AWW WASHER-TOP LOADING
Maytag SAV505DAWQ WASHER-TOP LOADING
Maytag SAV505DAWW WASHER-TOP LOADING
Maytag SAV515DAWW WASHER-TOP LOADING
Maytag SAV515DEWW WASHER-TOP LOADING
Maytag SAV5300AWW WASHER-TOP LOADING
Maytag SAV5401AWW WASHER-TOP LOADING
Maytag SAV5600AWW WASHER-TOP LOADING
Maytag SAV5701AWQ WASHER-TOP LOADING
Maytag SAV5701AWW WASHER-TOP LOADING
Maytag SAV5710AWW WASHER-TOP LOADING
Maytag SAV571EEWW WASHER-TOP LOADING
Maytag SAV5910AWW WASHER-TOP LOADING
Maytag SAV5910EWW WASHER-TOP LOADING
Maytag SAW25K3S WASHER-TOP LOADING
Whirlpool SAWB600HQ0 AUTOMATIC WASHER
Whirlpool SAWB600JQ0 WASHER
Whirlpool SAWB600JQ1 WASHER - DIRECT DRIVE
Whirlpool SAWS800HQ0 AUTOMATIC WASHER
Whirlpool SAWS800JQ0 WASHER
Whirlpool SAWS800JQ1 WASHER - DIRECT DRIVE
Whirlpool SAWS800JQ2 WASHER
Whirlpool SAWS800MQ0 AUTOMATIC WASHER
Whirlpool SAWS900HQ0 WASHER
Whirlpool SAWS900JQ0 WASHER - DIRECT DRIVE
Whirlpool SAWS900MQ0 AUTOMATIC WASHER
Whirlpool SAWX650JQ0 WASHER
Whirlpool SAWX650MQ0 AUTOMATIC WASHER
Whirlpool SAWX650MQ2 AUTOMATIC WASHER
Whirlpool SB1000SKN0 BUILT-IN GAS OVEN
Whirlpool SB100PEDB0 24" GAS BUILT-IN OVEN STANDARD CLEAN
Whirlpool SB100PEDB1 24" GAS BUILT-IN STANDARD CLEAN OVEN
Whirlpool SB100PEDB2 24" GAS BUILT-IN-OVEN STANDARD CLEAN
Whirlpool SB100PEDB4 GAS RANGE AND OVEN
Whirlpool SB100PEDB5 24" GAS SLIDE-IN RANGE
Whirlpool SB100PEK1 BUILT-IN GAS OVEN
Whirlpool SB100PER0 Range (gas)*
Whirlpool SB100PES0 Range (gas)*
Whirlpool SB100PES1 Range (gas)*
Whirlpool SB100PES2 Range (gas)*
Whirlpool SB100PES3 Range (gas)*
Whirlpool SB100PES4 GAS RANGES & OVENS
Whirlpool SB100PSK0 BUILT-IN GAS OVEN
Whirlpool SB100PSK1 BUILT-IN GAS OVEN
Whirlpool SB100PSR0 Range (gas)*
Whirlpool SB100PSR1 Range (gas)*
Whirlpool SB130PEDB0 24" GAS BUILT-IN OVEN CONTINUOUS CLEAN
Whirlpool SB130PEDB1 24" GAS BUILT-IN CONTINUOUS CLEAN OVEN
Whirlpool SB130PEDB2 24" GAS BUILT-IN-OVEN CONTINUOUS CLEAN
Whirlpool SB130PEK0 BUILT-IN GAS OVEN
Whirlpool SB130PER1 Range (gas)*
Whirlpool SB130PER2 Range (gas)*
Whirlpool SB130PER3 Range (gas)*
Whirlpool SB130PER4 GAS BUILT-IN OVEN
Whirlpool SB130PER5 24" GAS BUILT-IN OVEN ELECTRONIC IGNITION CONTINUOUS CLEAN OVEN
Whirlpool SB130PERW0 Range (gas)*
Whirlpool SB130PSK0 BUILT-IN GAS OVEN
Whirlpool SB160PEDB0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB2 24" BUILT-IN-OVEN
Whirlpool SB160PEDB4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ2 24" BUILT-IN-OVEN
Whirlpool SB160PEDQ4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEEB1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEB2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEB5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEB6 BUILT-IN GAS OVEN
Whirlpool SB160PEEB7 BUILT-IN GAS OVEN
Whirlpool SB160PEEB8 BUILT-IN GAS OVEN
Whirlpool SB160PEEB9 BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEQ2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEQ6 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ7 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ8 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ9 BUILT-IN OVEN, GAS
Whirlpool SB160PEXB0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ1 BUILT IN GAS OVEN
Amana SB21VE REF - SXS/I&W
Amana SB21VPSE REF - SXS/I&W
Amana SB21VW REF - SXS/I&W
Thermador SB2B
Amana SB520K REF - SXS/I&W
Amana SB520SW REF - SXS/I&W
Amana SB520TW REF - SXS/I&W
Amana SBC24FX0 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FX5 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FXOW RANGE - ELECTRIC STD DELAWARE
Amana SBC26CK RANGE - ELECTRIC STD DELAWARE
Amana SBD20H REF - SXS/I&W
Amana SBD20J Ref - SXS/I&W
Amana SBD20K REF - SXS/I&W
Amana SBD20M REF - SXS/I&W
Amana SBD20MW REF - SXS/I&W
Amana SBD20NE REF - SXS/I&W
Amana SBD20NW REF - SXS/I&W
Amana SBD20Q2E REF - SXS/I&W
Amana SBD20Q2W REF - SXS/I&W
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer cycle stops but timer keeps going texwreckage Washer Repair 3 04-23-2013 07:39 AM
Dryer Timer Stops in middle of cycle dterbeest Dryer Repair 1 09-14-2010 03:48 PM
Timer stops, hums, won't go into spin cycle kawal Washer Repair 1 01-14-2010 04:23 PM
Dryer & Timer Stops Mid Cycle nashville rookie Dryer Repair 8 10-22-2009 03:43 PM
Timer stops after wash cycle YODAUSA Washer Repair 5 05-13-2008 12:12 PM
