Discuss
Maytag Epic Z washer
 in
Washer Repair
While I was on vacation, my housesitter could not get my Maytag model MHWZ400TQ02 to work. Upon my return, I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Epic Z washer
  #1 (permalink)
Old 09-16-2014, 10:34 AM
Junior Member
MM53 is on a distinguished road
Default Maytag Epic Z washer
Brand: Maytag   Age: 5 - 10 years
While I was on vacation, my housesitter could not get my Maytag model MHWZ400TQ02 to work. Upon my return, I found that the washer dies when the start button is pushed. The door locks, I can hear relays clicking, then there is a buzz and all the front panel lights go out except for the door locked light. No error code is displayed. The door has to be opened with the manual release tab.
After reading about similar issues here and elsewhere and following steps in the Tech Data Sheet, I performed the following tests:
The diagnostic test results in an F01 error. Continued to click through error codes - all F01. Then all the lights light for 5 seconds, relays click, there is a buzz and all of the lights go out except the door locked light.
Inlet valves ohm out at 807 and 824 ohms. OK per the "job aid". The cable from the valves to connector VCH7 at the CCU ohms out as good. Water pressure is good and the screens are clean.
Pump motor ohms out at 13 ohms. OK per Tech Data Sheet.
Checked door switch circuit via DS2 connector. Ohmeter shows complete circuit when door is closed, open circuit when door is open.
The coin filter had a few coins in it. I cleaned it out and tested that water was flowing freely between the drum and the filter.
Here's where my tests fail.
Connector DL3 at the CCU pins 2 and 3 ohm out at 65 ohms. Between pins 1 and 3 reads 123 ohms. The job aid says both should be 60 ohms.
Connector DL3 between pins 1 and 2 reads zero voltage when start is pressed. Between pins 2 and 3 is also zero. An earlier post here says you should get 120VAC there.
Can I assume the door switch is bad?
Thanks in advance.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Epic Z Washer Will Not Fully Drain clewisch Washer Repair 3 07-09-2015 12:03 PM
Maytag Epic Z Washer Door Locks but won't turn on bmmcaloway Washer Repair 1 11-14-2013 04:00 PM
Maytag Epic Z Washer mrsjenhickman Washer Repair 3 04-19-2013 02:04 PM
Maytag Epic Z front load washer bellows replacement Andrew M Washer Repair 0 03-16-2011 08:14 PM
maytag washer -epic z misterfixall Washer Repair 2 04-16-2010 11:01 AM
