Model 11020022011. Lid lock light flashes. fill light comes on lid lock mlight comes on goes out then comes back on and starts to flash. After awhile lid lock light goes out and washer runs thru ccyle without agitating or spinning. fills and drains Have replaced lid lock assembly and control board per suggestions from others
Groups: Expert
Probably a faulty shift actuator but you need to retrieve the tech manual from inside the cabinet. Follow directions to place machine in diagnostic mode and check for error codes.
Eric
