carkor
#1 Posted : Friday, September 12, 2014 10:56:17 AM(UTC)
carkor
We have replaced the control panel, the lid lock assembly and today the user control and display board and are still having the same problem. The dial lights up and blinks, the machine keeps beeping and a du error is displayed. Nothing else happens. Help!
#2 Posted : Saturday, September 13, 2014 7:23:44 AM(UTC)
Have you checked the resistance at the control board as per the tech sheet?
Could be you have a bad wire/connection.
carkor
#3 Posted : Saturday, September 13, 2014 1:04:48 PM(UTC)
carkor
How do you check it? We have a multimeter but aren't sure how to use it. Sorry, we may be way out of our league but now our son is here too trying to figure it out.
#4 Posted : Sunday, September 14, 2014 4:23:12 AM(UTC)
Do you have the tech sheet?
Below is my usual blurb multimeter/ohmmeter usage.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
