washer works but will not go through the cycles,dial wont move.i have to manuallly move to next cycle any help.thinking timer but not sure thanks
The timer has a little motor that moves it along, and that part is integrated into the timer.
Replacing the timer should fix things, and if you buy from this site and that is not the solution you can return the part.
