scooter357
#1 Posted : Tuesday, September 9, 2014 9:23:03 PM(UTC)
scooter357
My GE washer will fill and agitate but will not drain or spin. The timer continues to make the usual clicking noise and advances all the way through the cycle even though nothing is happening. One time I pushed the control knob in to turn it off and the clicking sound continued even with the knob in the off position. Does this sound a lid switch problem or an issue with the timer?
fairbank56
#2 Posted : Wednesday, September 10, 2014 3:33:52 AM(UTC)
fairbank56
Groups: Expert
When agitation stops and it is supposed to go into drain, do you hear any noise from the drain pump? If yes, then there must be a clog or the pump is failing. The washer must be drained before it can spin. If there is no noise from the pump then you need to check for 120vac at the pump wiring terminals. If you have power there, then you need to replace the pump. If no power, then looks like a bad timer. The lid switch is fine or else it would not agitate.
Eric
scooter357
#3 Posted : Wednesday, September 10, 2014 5:11:31 PM(UTC)
scooter357
Eric
Thank you very much. I will check that out and I appreciate your help!
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag LA882 Washer (Dishwasher Repair)
by soloRepairer 3/30/2024 2:12:38 PM(UTC)
Maytag centennial washer- motor won’t spin (Washer Repair)
by Guest 3/30/2024 1:59:24 PM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Replacing a stacking Bosch Axxis+ Washer (Washer Repair)
by DonLafontaine 3/22/2024 3:59:06 AM(UTC)
Kenmore series 90 washer stopped working (Washer Repair)
by Guest 3/16/2024 6:19:45 AM(UTC)
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Amanda washer intermittently wont fill (Washer Repair)
by Guest 3/13/2024 3:48:07 PM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
