Jmccal7
#1 Posted : Tuesday, September 9, 2014 7:24:00 PM(UTC)
Jmccal7
Hello, I have a top load whirlpool washer model WTW5300VW2. The washer was working perfectly fine until one day I went to use it and right when the washer was about to fill, smoke started coming out instead of water. The smoke was coming out of the section where the water usually fills from. Also, when this occurred, there was noise coming from one of the water hoses connected to the back of the washer. I unplugged the power to the washer after this. I used the washer again today and everything works as expected, however, you have to manually fill the water into the tub to get the water to work. I did some research online and it seems that the water fill valve may be having an issue. Please correct me if I am wrong or if anyone has an answer to this issue. Would the water fill valve be the correct part to replace?
Thank you,
Joseph
Jmccal7
#2 Posted : Thursday, September 11, 2014 10:51:29 PM(UTC)
Jmccal7
Bump. Anyone have any ideas? Would like to get this fixed soon. Thanks
fairbank56
#3 Posted : Friday, September 12, 2014 3:33:28 AM(UTC)
fairbank56
Groups: Expert
I would check the wiring harness around the water inlet valve assembly. If all seems ok, then replace the valve assembly.
Whirlpool W10144820 Valve - AppliancePartsPros.com
Eric
Whirlpool washer won't fill with cold water (Washer Repair)
by tjwinters 3/17/2013 12:43:54 PM(UTC)
Whirlpool Washer Won't fill (Washer Repair)
by jamie_pancake@yahoo.com 9/22/2012 3:32:02 PM(UTC)
Whirlpool washer won't fill (Washer Repair)
by Wilmalcolm 7/28/2012 4:42:25 AM(UTC)
whirlpool washer won't fill (Washer Repair)
by rambo2 3/5/2012 8:36:41 AM(UTC)
Whirlpool Washer won't fill (Washer Repair)
by Katheryn 1/2/2012 8:55:52 AM(UTC)
Whirlpool Washer Won't Fill (Washer Repair)
by bjm46 11/15/2008 1:25:50 PM(UTC)
Whirlpool washer won't fill with water (Washer Repair)
by Evonne 10/22/2008 12:52:24 PM(UTC)
