socalwriter
#1 Posted : Wednesday, August 27, 2014 4:03:05 PM(UTC)
socalwriter
Pump has 120 volts going the motor, but will not turn pump. I took the pump out so I could see if it was turning, the pump is brand new. I even returned it to get another one, that doesn't work either, even though I have 120 volts going to it.
sidfink43
#2 Posted : Wednesday, August 27, 2014 5:22:14 PM(UTC)
sidfink43
If it really does have the voltage than this is somewhat of a mystery. I can only think that either the pump is jammed inside the housing or that something is blocking the drain hoses either to or from the pump.
Whirlpool Duet MDL# WWF8400TW02 New Drain Pump (Washer Repair)
by 1Oskydoodle! 3/30/2024 10:30:29 AM(UTC)
Whirlpool heat pump dryers (Dryer Repair)
by Aptmtncguy 1/19/2024 3:44:50 PM(UTC)
Siemens dishwasher pump keeps running (Dishwasher Repair)
by Fweigel 12/30/2023 4:35:28 AM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
Bosch ventless dryer sump pump not working (Dryer Repair)
by mdavidson 11/18/2023 2:22:57 AM(UTC)
Kitchenaid dishwasher pump? (Dishwasher Repair)
by Guest 6/11/2023 10:15:41 AM(UTC)
Rheem RQNJ-A048JK000 heat pump (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 5/16/2023 7:10:38 AM(UTC)
GE GTW330ASK1WW circulator pump and spinn test just does nothing (Washer Repair)
by tommalia@ttdsinc.com 3/10/2023 3:41:31 PM(UTC)
Noisy LG Drain Pump (Washer Repair)
by Guest 1/13/2023 3:19:30 PM(UTC)
drain pump on lid locked (Washer Repair)
by Randero 7/6/2022 5:32:07 AM(UTC)
Maytag 5500 drain/pump issues (Washer Repair)
by mlp141 6/26/2022 7:06:24 PM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Pump for a Kenmore 3.5 super capacity (Washer Repair)
by Guest 4/17/2022 10:34:55 AM(UTC)
Quiet partner buzzing while pumping (Dishwasher Repair)
by Guest 3/10/2022 9:03:14 AM(UTC)
LG Washer Drain Pump Noise (Washer Repair)
by Guest 1/28/2022 8:06:10 AM(UTC)
