Symptom is that it will appear as if there is no power. If I unplug the connector from the noise filter and plug it back in...then the washer powers up. Here's what I have done to diagnose: - 120V input to the noise filter - 120V output from the noise filter - When it appears without power I can see the red led on the main board is on
Again, if I unplug/plug one of the connectors on the noise filter the unit will come on for awhile...also there is a bit of a spark when I plug the connector in.
Is this a failing main board?
Thanks, Jack
