Bought a replacement Dain pump and installed yesterday. Part fit fine. New Issue IE Code - Went through all the normal solutions and what I found was the Drain Pump stays on when it tries to fill emptying the washer.
Power off the main board shows 115volts during the entire cycle until it faults out.
Could it be the pressure sensor? Or do you think the main PC Board is shot. After looking for the board - it's No Longer Available.
Any suggestions - Was just going to buy a new board but think i'm screwed.
