mcfall3504
#1 Posted : Friday, August 22, 2014 1:59:54 PM(UTC)
mcfall3504
Washer seems to run then won't spin. Used to be able to coax it to spin on "Drain and Spin" cycle. Now it won't spin at all. When it first started giving me trouble, it would start to spin and then stop. Now the lid lock light flashes most of the time. I am livid!!!!!!!!!!!!!!!!!!!!!!
fairbank56
#2 Posted : Friday, August 22, 2014 3:25:21 PM(UTC)
fairbank56
Groups: Expert
Open the top panel and retrieve the tech sheet from inside the cabinet. Instructions for opening top below. Follow the directions on tech sheet to get into service mode to retrieve any error codes and post them here. I think you most likely either have something in the drain pump or the shift actuator is bad.
Eric
UserPostedImage
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Maytag Oasis HE Washing Machine (Washer Repair)
by Guest 12/8/2023 12:55:45 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool model wtw7300dw2 washing machine (Washer Repair)
by Guest 11/8/2023 9:27:17 AM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Washing machine not washing clothes properly (Washer Repair)
by Guest 9/20/2023 11:56:24 AM(UTC)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Washing machine do not complete the cycle (Washer Repair)
by Guest 8/16/2023 10:02:15 AM(UTC)
Mayag washing machine - possibly locked motor? (Washer Repair)
by crp0499 5/19/2023 3:02:19 AM(UTC)
Recommended replacement for WP22001311 Maytag Washing Machine Unbalance lever (Washer Repair)
by Guest 4/29/2023 12:17:37 PM(UTC)
Whirlpool washing machine drive hub (Washer Repair)
by Guest 4/23/2023 7:29:26 AM(UTC)
Extension hose for GE washing machine GFW850SPNRS (Washer Repair)
by Guest 3/17/2023 9:53:53 PM(UTC)
Maytag washing machine MHW6630HW - looking for electrical diagram (Washer Repair)
by jessman1128 2/8/2023 12:45:11 PM(UTC)
