the title says it all, the agitator starts its movement before the tub fills with water and the agitator emits a banging noise.....HELP
Groups: Expert
Any way to check it before I order one? My wife states she never uses that switch
Groups: Expert
Doesn't matter whether you use it or not, the control board inside of it is always used to control washer filling. The pressure sensor that determines when agitation starts is part of the control board. The control is a high failure item in these load sensing washers.
Eric
