Yesterday I washed a blanket, returned to the lid lock sign on, turned off the power and looked inside to a drum half full of water with the blanket in it, turned it back on to the Drain spin cycle, returned to the locked lid sign again and washer still full, I proceeded to removing the soaked blacket and dry vac the water out of the drum, and tried to run a normal cycle, it once again went to the lock lid sign, i attemped several times to drain, clean and start another cycle with it, and watched it everytime it would start as sensening then switch straight to the spin cycle and turn itself off and the lock lid sign would still be on. I even tried unplugging it and still would so this. can you help guide me in what might be the problem? thank you.
