Discuss
How do I remove manifold trap from tub?
 in
Washer Repair
I'm refurbishing the tub on this 30-year old machine, and there's some rust around the gasket holding
Appliance Repair Forum > Appliance Repair Help > Washer Repair » How do I remove manifold trap from tub?
  #1 (permalink)
Old 02-16-2008, 10:00 PM
Sensible Sensible is offline
Junior Member
Sensible is on a distinguished road
Default How do I remove manifold trap from tub?
Model Number: 11074690600   Brand: Kenmore   Age: More than 10 years
I'm refurbishing the tub on this 30-year old machine, and there's some rust around the gasket holding the manifold trap (tub drain). I want to remove the trap so I can refinish this opening.
My Kenmore belt drives repair manual shows a trap, and a replacement tub without it, but doesn't mention how to attach or detach the trap assembly from the tub. Anyone know how, without damaging the trap?
Although functionally the same as the manifold trap shown in my manual, it differs from the manual's picture. Mine is a white plastic tube inside a formed black rubber part. The black rubber includes the outlet hose connection, and the whole assembly is held in place by either a rubber gasket or the top of the rubbery part, I'm not sure.)
I suppose I could remove the trap by deforming the gasket section with a big screwdriver, but that would probably damage it and I don't have a replacement. I've removed the outlet hose, and the trap turns 360 degrees but doesn't seem to be screwed or slotted in.
Related Models
Kenmore 11074712200 GAS DRYER
Kenmore 11074812200 GAS DRYER
Kenmore 11074902200 GAS DRYER
Kenmore 11074912200 GAS DRYER
Kenmore 11074922200 GAS DRYER
Kenmore 11074924200 GAS DRYER
Kenmore 11074932200 GAS DRYER
Kenmore 11075193 AUT. WASHER GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 11075601 AUT. WASHER GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 11076401100 KENMORE ELECTRIC DRYER
Kenmore 11076401400 KENMORE ELECTRIC DRYER
Kenmore 11076401600 KENMORE ELECTRIC DRYER
Kenmore 11076402100 KENMORE ELECTRIC DRYER
Kenmore 11076402400 KENMORE ELECTRIC DRYER
Kenmore 11076402600 KENMORE ELECTRIC DRYER
Kenmore 11076403100 KENMORE ELECTRIC DRYER
Kenmore 11076403400 KENMORE ELECTRIC DRYER
Kenmore 11076403600 KENMORE ELECTRIC DRYER
Kenmore 11076404100 KENMORE ELECTRIC DRYER
Kenmore 11076404110 SEARS ELECTRIC DRYER
Kenmore 11076405100 KENMORE ELECTRIC DRYER
Kenmore 11076405400 KENMORE ELECTRIC DRYER
Kenmore 11076405600 KENMORE ELECTRIC DRYER
Kenmore 11076406100 KENMORE ELECTRIC DRYER
Kenmore 11076406400 KENMORE ELECTRIC DRYER
Kenmore 11076406600 KENMORE ELECTRIC DRYER
Kenmore 11076407100 KENMORE ELECTRIC DRYER
Kenmore 11076407400 KENMORE ELECTRIC DRYER
Kenmore 11076407600 KENMORE ELECTRIC DRYER
Kenmore 11076408100 KENMORE ELECTRIC DRYER
Kenmore 11076408110 SEARS ELECTRIC DRYER
Kenmore 11076408120 ELECTRIC DRYER
Kenmore 11076408130 ELECTRIC DRYER
Kenmore 11076408140 ELECTRIC DRYER
Kenmore 11076408150 ELECTRIC DRYER
Kenmore 11076408160 ELECTRIC DRYER
Kenmore 11076408220 ELECTRIC DRYER
Kenmore 11076408230 ELECTRIC DRYER
Kenmore 11076408240 ELECTRIC DRYER
Kenmore 11076408250 ELECTRIC DRYER
Kenmore 11076408400 KENMORE ELECTRIC DRYER
Kenmore 11076512690 ELECTRIC DRYER
Kenmore 11076801690 ELECTRIC DRYER
Kenmore 11076812690 ELECTRIC DRYER
Kenmore 11076822690 SUPER CAPACITY PLUS CLOTHES DRYER
Kenmore 11076852690 ELECTRIC DRYER
Kenmore 11077401100 KENMORE GAS DRYER
Kenmore 11077401110 KENMORE GAS DRYER
Kenmore 11077401120 GAS DRYER
Kenmore 11077401400 KENMORE GAS DRYER
Kenmore 11077401410 KENMORE GAS DRYER
Kenmore 11077401420 GAS DRYER
Kenmore 11077401600 KENMORE GAS DRYER
Kenmore 11077401610 KENMORE GAS DRYER
Kenmore 11077401620 GAS DRYER
Kenmore 11077408160 GAS DRYER
Kenmore 11077408660 GAS DRYER
Kenmore 11077408860 GAS DRYER
Kenmore 11077409150 GAS DRYER
Kenmore 11077409650 GAS DRYER
Kenmore 11077409850 GAS DRYER
Kenmore 11077410100 KENMORE GAS DRYER
Kenmore 11077490100 KENMORE GAS DRYER
Kenmore 11077490200 KENMORE GAS DRYER
Kenmore 11077490400 KENMORE GAS DRYER
Kenmore 11077490600 KENMORE GAS DRYER
Kenmore 11077611100 KENMORE GAS DRYER
Kenmore 11077640100 KENMORE GAS DRYER
Kenmore 11077645100 KNEMORE GAS DRYER
Kenmore 11077675100 KENMORE GAS DRYER
Kenmore 11077675200 KENMORE GAS DRYER
Kenmore 11077675400 KENMORE GAS DRYER
Kenmore 11077675600 KENMORE GAS DRYER
Kenmore 11077732790 ELECTRIC DRYER
Kenmore 11077732791 GAS DRYER
Kenmore 11077732792 GAS DRYER
Kenmore 11077732794 GAS DRYER
Kenmore 11077732795 GAS DRYER
Kenmore 11077832790 ELECTRIC DRYER
Kenmore 11077832791 GAS DRYER
Kenmore 11077832792 GAS DRYER
Kenmore 11077832794 GAS DRYER
Kenmore 11077832795 GAS DRYER
Kenmore 11077834790 GAS DRYER
Kenmore 11077834791 GAS DRYER
Kenmore 11077834794 GAS DRYER
Kenmore 11077834795 GAS DRYER
Kenmore 11078202790 GAS DRYER
Kenmore 11078202794 GAS DRYER
Kenmore 11078202795 GAS DRYER
Kenmore 11078410100 KENMORE ELECTRIC DRYER
Kenmore 11078410110 KENMORE ELECTRIC DRYER
Kenmore 11078410200 KENMORE ELECTRIC DRYER
Kenmore 11078410210 KENMORE ELECTRIC DRYER
Kenmore 11078410400 KENMORE ELECTRIC DRYER
Kenmore 11078410410 KENMORE ELECTRIC DRYER
Kenmore 11078410600 KENMORE ELECTRIC DRYER
Kenmore 11078410610 KENMORE ELECTRIC DRYER
Kenmore 11078411100 KENMORE ELECTRIC DRYER
Kenmore 11078411110 KENMORE ELECTRIC DRYER
Kenmore 11078411200 KENMORE ELECTRIC DRYER
Kenmore 11078411210 KENMORE ELECTRIC DRYER
Kenmore 11078411400 KENMORE ELECTRIC DRYER
Kenmore 11078411410 KENMORE ELECTRIC DRYER
Kenmore 11078411600 KENMORE ELECTRIC DRYER
Kenmore 11078411610 KENMORE ELECTRIC DRYER
Kenmore 11078412100 KENMORE ELECTRIC DRYER
Kenmore 11078412200 KENMORE ELECTRIC DRYER
Kenmore 11078412400 KENMORE ELECTRIC DRYER
Kenmore 11078412600 KENMORE ELECTRIC DRYER
Kenmore 11078413100 KENMORE ELECTRIC DRYER
Kenmore 11078413200 KENMORE ELECTRIC DRYER
Kenmore 11078413400 KENMORE ELECTRIC DRYER
Kenmore 11078413600 KENMORE ELECTRIC DRYER
Kenmore 11078413800 KENMORE ELECTRIC DRYER
Kenmore 11078414100 KENMORE ELECTRIC DRYER
Kenmore 11078414200 KENMORE ELECTRIC DRYER
Kenmore 11078414400 KENMORE ELECTRIC DRYER
Kenmore 11078414600 KENMORE ELECTRIC DRYER
Kenmore 11078414800 KENMORE ELECTRIC DRYER
  #2 (permalink)
Old 02-17-2008, 04:07 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Lay the washer on its front and loosen the screw clamp around the pin trap, then remove trap.
__________________
  #3 (permalink)
Old 02-17-2008, 10:50 AM
Junior Member
Default
Thanks, but that's not it. It seems there might be two types, your type being as described in the repair manual.
Mine is different. There's a hose clamp (OEM spring clamp, not screw-type) around the connection to the pump, but no clamp at the top of the trap, where it meets the tub. Looks like the black rubber that forms the trap extends into the tub, forming a gasket. Viewed from the top of the trap (from inside the tub), this assembly appears as a black gasket ring surrounding a white ring (the top of the white plastic tubelike structure that's inside the rubber exterior). No hose, no seam, no clamp.
The outer tub is already removed from my washer, so that's not an issue.
(BTW, I'm assuming "pin trap" and "manifold trap" are the same thing.)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How do I remove the relay? pcalk Refrigerator & Freezer Repair 0 02-12-2008 01:17 PM
How to remove basket lbrock Washer Repair 1 10-02-2007 04:04 AM
Wrench To Remove Nut To Remove Tub JIMMEER Washer Repair 1 10-01-2007 05:13 AM
Remove the Top j_lavine Dryer Repair 1 08-21-2007 08:49 PM
Can't remove top BoyBlue Dryer Repair 1 08-20-2007 12:49 PM
