I have a Maytag Neptune model mah7500aww front load. Everything works fine but the washer never completely empties. I can hear water splashing when I manually turn the tub, however, no water is visible. Standing water has resulted in a musty odor and mildewed gasket. Is this repairable?
The first thing to do is to check the pump and the lines coming from the tub to the pump and then out to the drain pipe. Cleaning them out may solve the probem, hopefully so.
