my washer overfilled so I replaced water level pressure switch and the water level and water pump works fine but will not agitate or spin.
Okay, this model has some electronics on the motor so hopefully the water did not short something out and ruin it. Start by checking for error codes with the flashing light on the motor. But first go through the reset routine and check the in line fuse along the right. Here is a link as to how to interpret the codes. HydroWave GE Washer Repair Guidegood luck!
