I know it means no drain!!! The pump works hose is clear of obstruction I found a quarter n pump but pump is fine..When hooked up to washer tho its not getting power this I know cause I unhooked the intake line and turned washer to spin cycle and held pump n hand and watched for spinning impeller and nope no spinning impeller. .is there a fuse inside washer some place that needs reset?
