Discuss
Whirlpool washer - won't high speed spin
 in
Washer Repair
The washer will not high speed spin. It agitates, drains and spins with the normal speed. Originally it would not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer - won't high speed spin
  #1 (permalink)
Old 10-24-2009, 12:05 PM
Junior Member
GerryW is on a distinguished road
Default Whirlpool washer - won't high speed spin
Model Number: LSW9700PQ1   Brand: Whirlpool   Age: 1 - 5 years
Originally it would not spin at all (agitated and drained) but I noticed that the plastic part of the lid sensor was broken so the lid hinge was unable to turn the sensor properly. I removed the sensor and blocked it with a small screw driver so it is ON all the time. I also removed the washer cabinet. After this change the washer spins with the normal speed (I see the clutch is spinning) but when it comes to the high speed cycle it does not spin at all.
In this stage the motor works, the water pump works (water drained), but the clutch is not spinning and the basked is locked (I cannot even rotate it with my hands). The noises generated in this stage are like the washer wants to spin but something is blocked not allowing to spin. At the same time the timer is progressing its cycle.
- I removed the water pump and motor. The coupling is in a perfect condition. All around looks like new.
The only suspicious observation is: small amount of oil droplets inside the cabinet on the side walls about 5 inches from the bottom.
I am not sure what test to complete next. I have read everything I could find about Whirlpool washers spinning problems in this forum and on the WEB in general but still not sure which component should I replace in this case.
I will appreciate your advice.
GerryW
Ads By Google
Related Models
Whirlpool LSW9700PQ1 Automatic Washer
Whirlpool LSW9700PQ2 Automatic Washer
Whirlpool LSW9750PW0 Automatic Washer
Whirlpool LSW9750PW1 Automatic Washer
Whirlpool LSW9750PW2 Automatic Washer
Whirlpool LSW9750PW3 Automatic Washer
Frigidaire LT150EXD2 Wwh(v1) / Tumble Action Washer
Frigidaire LT150EXF2 Wwh(v2) / Tumble Action Washer
Frigidaire LT150EXH2 Wwh(v3) / Tumble Action Washer
Frigidaire LT150EXV2 Wwh(v4) / Tumble Action Washer
Frigidaire LT150EXW2 Wwh(v5) / Tumble Action Washer
Frigidaire LT150JXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT150JXF1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150JXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150JXV1 Wwh(v4) / Tumble Action Washer
Frigidaire LT150JXW1 Wwh(v5) / Tumble Action Washer
Frigidaire LT150LXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150LXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150LXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT200PXD2 Wwh(v2) / 27 " Front Load Washer
Frigidaire LT200PXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXW2 Wwh(v1) / 27 " Front Load Washer
Frigidaire LT250EXD2 Wwh(v6) / Tumble Action Washer
Frigidaire LT250EXD4 Wwh(v7) / Tumble Action Washer
Frigidaire LT250EXF2 Wwh(v8) / Tumble Action Washer
Frigidaire LT250EXF4 Wwh(v9) / Tumble Action Washer
Frigidaire LT250EXH2 Wwh(v10) / Tumble Action Washer
Frigidaire LT250EXH4 Wwh(v11) / Tumble Action Washer
Frigidaire LT250EXV2 Wwh(v12) / Tumble Action Washer
Frigidaire LT250EXV4 Wwh(v13) / Tumble Action Washer
Frigidaire LT250EXW2 Wwh(v14) / Tumble Action Washer
Frigidaire LT250EXW4 Wwh(v15) / Tumble Action Washer
Frigidaire LT250JXD1 Wwh(v6) / Tumble Action Washer
Frigidaire LT250JXF1 Wwh(v7) / Tumble Action Washer
Frigidaire LT250JXH1 Wwh(v8) / Tumble Action Washer
Frigidaire LT250JXV1 Wwh(v9) / Tumble Action Washer
Frigidaire LT250JXW1 Wwh(v10) / Tumble Action Washer
Frigidaire LT250LXD1 Wwh(v5) / Tumble Action Washer
Frigidaire LT250LXH1 Wwh(v6) / Tumble Action Washer
Frigidaire LT250LXW1 Wwh(v4) / Tumble Action Washer
Frigidaire LT350RXD1 Wwh(v2) / 27 " Front Load Washer
Frigidaire LT350RXW1 Wwh(v1) / 27 " Front Load Washer
Whirlpool LT4900XMW0
Whirlpool LT4900XMW1
Whirlpool LT4900XMW2
Whirlpool LT4900XSW1
Whirlpool LT4900XSW2
Whirlpool LT4900XSW3
Whirlpool LT4905XMW0
Whirlpool LT5000XLW0
Whirlpool LT5000XMW0
Whirlpool LT5000XMW1
Whirlpool LT5000XSW1
Whirlpool LT5000XSW2
Whirlpool LT5000XSW3
Whirlpool LT5000XVN0
Whirlpool LT5000XVW0
Whirlpool LT5004XMW0
Whirlpool LT5004XMW1
Whirlpool LT5004XSW1
Whirlpool LT5004XSW2
Whirlpool LT5004XSW3
Whirlpool LT5004XVN0
Whirlpool LT5004XVW0
Whirlpool LT5005XMW0
Whirlpool LT5009XMW0
Whirlpool LT5100XSW0
Whirlpool LT5100XSW1
Whirlpool LT5100XVN0
Whirlpool LT5100XVW0
Frigidaire LT600EXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT600EXD4 Wwh(v2) / Tumble Action Washer
Frigidaire LT600EXF1 Wwh(v3) / Tumble Action Washer
Frigidaire LT600EXF4 Wwh(v4) / Tumble Action Washer
Frigidaire LT600EXH1 Wwh(v5) / Tumble Action Washer
Frigidaire LT600EXH4 Wwh(v6) / Tumble Action Washer
Frigidaire LT600EXV1 Wwh(v7) / Tumble Action Washer
Frigidaire LT600EXV4 Wwh(v8) / Tumble Action Washer
Frigidaire LT600EXW1 Wwh(v9) / Tumble Action Washer
Frigidaire LT600EXW4 Wwh(v10) / Tumble Action Washer
Frigidaire LT600JXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT600JXF1 Wwh(v2) / Tumble Action Washer
Frigidaire LT600JXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT600JXV1 Wwh(v4) / Tumble Action Washer
Frigidaire LT600JXW1 Wwh(v5) / Tumble Action Washer
Whirlpool LT7000XTF0
Whirlpool LT7000XTF1
Whirlpool LT7000XTG0
Whirlpool LT7000XTG1
Whirlpool LT7000XTM0
Whirlpool LT7000XTM1
Whirlpool LT7000XTN0
Whirlpool LT7000XTN1
Whirlpool LT7000XTW0
Whirlpool LT7000XTW1
Whirlpool LT7000XVN0
Whirlpool LT7000XVW0
Whirlpool LT7004XTF0
Whirlpool LT7004XTF1
Whirlpool LT7004XTG0
Whirlpool LT7004XTG1
Whirlpool LT7004XTM0
Whirlpool LT7004XTM1
Whirlpool LT7004XTN0
Whirlpool LT7004XTN1
Whirlpool LT7004XTW0
Whirlpool LT7004XTW1
Whirlpool LT7004XVW0
Frigidaire LT700EXD1 Wwh(v11) / Tumble Action Washer
Frigidaire LT700EXD4 Wwh(v12) / Tumble Action Washer
Frigidaire LT700EXD6 Wwh(v13) / Tumble Action Washer
Frigidaire LT700EXF1 Wwh(v14) / Tumble Action Washer
Frigidaire LT700EXF4 Wwh(v15) / Tumble Action Washer
Frigidaire LT700EXF6 Wwh(v16) / Tumble Action Washer
Frigidaire LT700EXH1 Wwh(v17) / Tumble Action Washer
Frigidaire LT700EXH4 Wwh(v18) / Tumble Action Washer
Frigidaire LT700EXH6 Wwh(v19) / Tumble Action Washer
Frigidaire LT700EXV1 Wwh(v20) / Tumble Action Washer
Frigidaire LT700EXV4 Wwh(v21) / Tumble Action Washer
  #2 (permalink)
Old 10-25-2009, 11:26 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
If it is spinning in slower mode then it would seem the transmission has failed, which would explain the oil you are seing.
If it will not spin in any mode it may be a brake problem. See the sticky by Richappy on brakes.
__________________
  #3 (permalink)
Old 10-30-2009, 06:57 PM
Junior Member
Default
Hello,
Thank you for the help with the troubleshooting.
I read the manual.
I found that, for the spinning problem, "if the clutch spins when the timer is set for spinning, the gearbox works OK" - a very important piece of information. The clutch was spinning in that setup in my washing machine. So, I moved my attention away from the gearbox.
Next, I found in this or another forum that "if the clutch gets hot when running in a spinning cycle, even for a short time, that means that the clutch is "sliding" and that is the reason that he washer does not spin". I checked the clutch in my washer after the spinning cycle and it was really hot.
I ordered the clutch.
I installed it today and the washer spins like a new one.
Thank you very much for all the help and assistance.
I still have one more problem, present just in one program "Normal Program", when the High Spin starts at the same time the washer also takes water. I have to turn OFF the timer and turn it ON again and the High Spin works as it supposed to. I thought I saw that problem reported by somebody but don't remember the solution.
I will appreciate an advice on this one.
Thank you again.
GerryW
  #4 (permalink)
Old 10-30-2009, 07:17 PM
Senior Expert
APP Volunteer
Default
Hi Gerry
Glad the new clutch fixed things. Given you initial description I am wondering if there was not a problem in the transmission, which you may have corrected when you took it out to replace the clutch. Anyway, sounds like things are working well.
If it injects just a spray of water at the beginning this is probably part of the process. These machines will inject water at the beginning of the spin process to do a final rinsing of the clothes. Of course, if water is coming in and filling up the tub that is not correct.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Front Load Washer - No High Speed Spin BLKJAK Washer Repair 4 05-13-2011 08:10 AM
no high speed spin DEEDEEGOGO Washer Repair 2 10-16-2009 01:35 PM
Haier washer no high speed spin richappy Washer Repair 0 09-07-2008 11:23 AM
Whirlpool washer won't spin to speed cardonef Washer Repair 3 06-30-2008 01:39 AM
Whirlpool Top load does not high speed spin howdyadothat Washer Repair 11 06-24-2008 12:14 PM
