I've done a lot of reading here about humming problems, but haven't seen quite what I have: I've been slowly working on this machine as I have time and/or a part arrives. Each time I hook it up (after several days at least), it will fill, no problem. Then it will agitate and drain if I keep it going. After that (a complete stop) it will not go into spin, but hums. Then it will do nothing else, no agitation, no draining, and no spinning. If I put the switch in "spin" to start with, it will spin, but then nothing. So, it works once after dormancy and then only hums. This happens every time I work on it. I have replaced: -motor coupler -start capacitor I have taken apart the pump and it is clear of obstructions & spins.
Any ideas from the geniuses out there? Thank you.
