Discuss
Washer spins but won't fill with water
 in
Washer Repair
The washer starter malfunctioning today. It will not fill with water. No matter where you place the dial to start
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer spins but won't fill with water
  #1 (permalink)
Old 07-04-2014, 02:36 PM
Junior Member
jlupfer is on a distinguished road
Default Washer spins but won't fill with water
Model Number: lsq9110pw3   Brand: Whirlpool   Age: 5 - 10 years
The washer starter malfunctioning today. It will not fill with water. No matter where you place the dial to start a cycle, the washer starts spinning immediately. Once it finishes the first spin cycle, and enters the rinse cycle, the washer stops, but won't fill, then starts spinning again until it reaches the "off" point. Do I have a bad switch?
Related Models
Whirlpool LSQ9110PW3 AUTOMATIC WASHER
Whirlpool LSQ9110PW4 AUTOMATIC WASHER
Whirlpool LSQ9200KQ0 WASHER
Whirlpool LSQ9200KT0 WASHER
Whirlpool LSQ9200LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9200LQ1 AUTOMATIC WASHER
Whirlpool LSQ9200LQ2 AUTOMATIC WASHER
Whirlpool LSQ9200LQ3 AUTOMATIC WASHER
Whirlpool LSQ9200LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9200LT1 AUTOMATIC WASHER
Whirlpool LSQ9200LT2 AUTOMATIC WASHER
Whirlpool LSQ9200LT3 AUTOMATIC WASHER
Whirlpool LSQ9200PQ0 AUTOMATIC WASHER
Whirlpool LSQ9200PQ1 AUTOMATIC WASHER
Whirlpool LSQ9200PQ3 AUTOMATIC WASHER
Whirlpool LSQ9200PQ4 AUTOMATIC WASHER
Whirlpool LSQ9200PT0 AUTOMATIC WASHER
Whirlpool LSQ9200PT1 AUTOMATIC WASHER
Whirlpool LSQ9200PT3 AUTOMATIC WASHER
Whirlpool LSQ9200PT4 AUTOMATIC WASHER
Whirlpool LSQ9210HQ0 AUTOMATIC WASHER
Whirlpool LSQ9210HZ0 AUTOMATIC WASHER
Whirlpool LSQ9211KQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9244EQ0 AUTOMATIC WASHER
Whirlpool LSQ9244EZ0 AUTOMATIC WASHER
Whirlpool LSQ9264HQ0 AUTOMATIC WASHER
Whirlpool LSQ9264HZ0 AUTOMATIC WASHER
Whirlpool LSQ9500LQ0 WASHER
Whirlpool LSQ9500LT0 WASHER
Whirlpool LSQ9510JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9510LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9544KQ0 WASHER
Whirlpool LSQ9544KT0 WASHER
Whirlpool LSQ9549LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LG1 AUTOMATIC WASHER
Whirlpool LSQ9549LG2 AUTOMATIC WASHER
Whirlpool LSQ9549LG3 AUTOMATIC WASHER
Whirlpool LSQ9549LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LQ1 AUTOMATIC WASHER
Whirlpool LSQ9549LQ2 AUTOMATIC WASHER
Whirlpool LSQ9549LQ3 AUTOMATIC WASHER
Whirlpool LSQ9549LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LW1 AUTOMATIC WASHER
Whirlpool LSQ9549LW2 AUTOMATIC WASHER
Whirlpool LSQ9549LW3 AUTOMATIC WASHER
Whirlpool LSQ9549PG0 AUTOMATIC WASHER
Whirlpool LSQ9549PG1 AUTOMATIC WASHER
Whirlpool LSQ9549PG2 AUTOMATIC WASHER
Whirlpool LSQ9549PG3 AUTOMATIC WASHER
Whirlpool LSQ9549PG5 AUTOMATIC WASHER
Whirlpool LSQ9549PG6 AUTOMATIC WASHER
Whirlpool LSQ9549PW0 AUTOMATIC WASHER
Whirlpool LSQ9549PW1 AUTOMATIC WASHER
Whirlpool LSQ9549PW2 AUTOMATIC WASHER
Whirlpool LSQ9549PW3 AUTOMATIC WASHER
Whirlpool LSQ9549PW5 AUTOMATIC WASHER
Whirlpool LSQ9549PW6 AUTOMATIC WASHER
Whirlpool LSQ9550PW0 AUTOMATIC WASHER
Whirlpool LSQ9550PW1 AUTOMATIC WASHER
Whirlpool LSQ9550PW2 AUTOMATIC WASHER
Whirlpool LSQ9550PW3 AUTOMATIC WASHER
Whirlpool LSQ9550PW4 AUTOMATIC WASHER
Whirlpool LSQ9560PW0 AUTOMATIC WASHER
Whirlpool LSQ9560PW1 AUTOMATIC WASHER
Whirlpool LSQ9560PW2 Residential Washer
Whirlpool LSQ9560PW3 AUTOMATIC WASHER
Whirlpool LSQ9560PW4 AUTOMATIC WASHER
Whirlpool LSQ9564JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JZ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564MQ0 AUTOMATIC WASHER
Whirlpool LSQ9565MQ0 WASHER
Whirlpool LSQ9600JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG1 AUTOMATIC WASHER
Whirlpool LSQ9600LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LW1 AUTOMATIC WASHER
Whirlpool LSQ9610JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610LG0 AUTOMATIC WASHER
Whirlpool LSQ9610LW0 AUTOMATIC WASHER
Whirlpool LSQ9620LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LG1 AUTOMATIC WASHER
Whirlpool LSQ9620LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LW1 AUTOMATIC WASHER
Whirlpool LSQ9645KQ0 WASHER
Whirlpool LSQ9645KQ1 WASHER
Whirlpool LSQ9645KT0 WASHER
Whirlpool LSQ9645KT1 WASHER
Whirlpool LSQ9650PG0 AUTOMATIC WASHER
Whirlpool LSQ9650PG1 AUTOMATIC WASHER
Whirlpool LSQ9650PG2 AUTOMATIC WASHER
Whirlpool LSQ9650PG3 AUTOMATIC WASHER
Whirlpool LSQ9650PG4 AUTOMATIC WASHER
Whirlpool LSQ9650PW0 AUTOMATIC WASHER
Whirlpool LSQ9650PW1 AUTOMATIC WASHER
Whirlpool LSQ9650PW2 AUTOMATIC WASHER
Whirlpool LSQ9650PW3 AUTOMATIC WASHER
Whirlpool LSQ9650PW4 AUTOMATIC WASHER
Whirlpool LSQ9659LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LG1 AUTOMATIC WASHER
Whirlpool LSQ9659LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LW1 AUTOMATIC WASHER
Whirlpool LSQ9659PG0 AUTOMATIC WASHER
Whirlpool LSQ9659PG1 AUTOMATIC WASHER
Whirlpool LSQ9659PG2 AUTOMATIC WASHER
  #2 (permalink)
Old 07-05-2014, 08:02 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Sounds like a faulty water level pressure switch (level control). Open control panel, unplug clear hose from pressure switch. Does it fill now? If not, disconnect wiring connector from switch and jump the violet and pink wires together. Does it fill now? If so, switch is bad.
Whirlpool W10335056 Switch-Wl - AppliancePartsPros.com
Eric
  #3 (permalink)
Old 07-14-2014, 04:12 PM
Junior Member
Default
I ran the test suggested above. Since the washer filled when I jumped the two wires, I replaced the switch. I did not replace the clear hose because I wanted to make sure it worked. I started the washer as with the new switch in in a normal wash cycle, and it filled as expected; it then went into the spin cycle. When I expected it to fill again for the rinse cycle, it did not fill and went straight to the agitate and then spin. I tried top get it to fill in other rinse cycles on the control dial and could not get it to fill. What am I missing? Bad Timer, control?
  #4 (permalink)
Old 07-14-2014, 06:21 PM
Expert
APP Volunteer
Default
Yes, it sounds like you also have a faulty timer. Strange symptoms though. If you buy timer from APP and it doesn't fix the problem, you may return it.
Whirlpool 3955765 Timer, Control (60 Hz.) (motor Not A Service Part) - AppliancePartsPros.com
Eric
  #5 (permalink)
Old 07-15-2014, 02:46 AM
Junior Member
Default
after posting these symptoms last night, here is what I did to complete a complete wash cycle:
-turn the dial to the start position for a normal wash cycle
-open the control panel and pull the clear hose from the switch
-pull the dial to start the flow of water then reattach the clear hose
-listen for the end of the first spin cycle and push the dial after the spin cycle switches off
-open the control panel and pull the clear hose from the switch, again
-pull the dial to start the flow of water then reattach the clear hose and let the washer run to the end of its cycle
Does this help at all?
  #6 (permalink)
Old 07-15-2014, 06:14 AM
Expert
APP Volunteer
Default
Yes, sounds like the hose or the air chamber that it attaches to on the tub may be clogged. This is common on GE washers but not so much on Whirlpool. You need to remove the cabinet and check the air dome and hose on the right rear part of the outer tub. You can clean the end of the hose out if it's clogged or flush out the air chamber if it has debris in it.
Eric
  #7 (permalink)
Old 07-16-2014, 10:23 AM
Junior Member
Default
Dumb question: how do you remove the air chamber? I can't get behind the washer to see it well enough to tell is there is a clip, or if it screws off. I replaced the hose, and the washer is starting its cycle properly, but the rising water level is not triggering the switch to start the agitation cycle, so I figure it must be the air chamber clogged up. I blew on the hose before setting it on the air chamber, and the switch mechanism clicked.
  #8 (permalink)
Old 07-16-2014, 10:49 AM
Expert
APP Volunteer
Default
It's not removable. Clean with a wire fished into hose inlet and flush with hot water using a turkey baster or similar device. Be careful not to break the hose nipple off.
Eric
  #9 (permalink)
Old 07-16-2014, 12:13 PM
Junior Member
Default
I ended up shooting a bleach-water mixture in, then blew air in with a compressor. It is working properly at the moment.
Thank you for all of your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer fills, agitates, drains, spins, won't fill to go on to rinse cycle. 1golf4 Washer Repair 2 09-24-2014 08:38 PM
GE Washer spins when full of water AVC741 Washer Repair 1 07-30-2013 04:43 PM
Washer spins but water does not drain Ed Marshall Washer Repair 1 06-07-2011 04:30 AM
Maytag Washer - Spins but doesn't Fill/Wash jdential Washer Repair 6 12-15-2009 01:41 PM
washer agitates and spins - won't fill wdhammy Washer Repair 3 03-27-2009 01:06 PM
