Problems started with a lid switch. Replaced lid switch with a new one even thoug the old one tested good with an ohmn meter.
The I said maybe the coupler, so I ordered a new one. I pulled the washer apart and got to the coupler. Guess what I found...Kenmore actually did a good thing. The coupler is in great shape, in fact it even has the metal inserts.
Short version. After putting the machine back together and making sure the lid switch can NOT move. The washer will not fill. Yes I have water to the machine. It works on the spin and rinse cycles but just not getting any water.
Thanks in advance Bob
