Washer won't drain. Took pump out ran 110 to To it works fine. Now what time snitch?...
Operate it with the front cover off and see if the pump is trying to run when it is in drain mode. If it is then an obstruction is the problem. If you are not getting 110/120 v at the pump (use a meter to check) then try changing out the timer. Check the wiring first to make sure you have continuity from the control unit.
