Washer will fill up but wont agitate, spin or drain. I hear a click and then a humming sound when I shut the lid but then no movement it only hums for about 15 seconds then kicks off.
This could be the lid switch but I think a more likely explanation is that something like a sock or an underthingee has gotten caught in the pump. Take off the cabinet and check it out. If the pump is okay make sure the coupling is not broken and jamming things.
If those are not the problem then bypass the lid switch, put it on spin and see if that works.
