Discuss
Washing Machine Has Only One Cycle (Gentle)
 in
Washer Repair
Washing machine agitates only on gentle speed regardless of knob indication, and spins only on low rpm. Even when switch
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washing Machine Has Only One Cycle (Gentle)
  #1 (permalink)
Old 06-06-2014, 11:15 AM
dkn dkn is offline
Junior Member
dkn is on a distinguished road
Default Washing Machine Has Only One Cycle (Gentle)
Brand: GE   Age: 5 - 10 years
Washing machine agitates only on gentle speed regardless of knob indication, and spins only on low rpm. Even when switch is on normal. Can someone help me with this problem?
  #2 (permalink)
Old 06-07-2014, 06:00 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Can you post a model number so we can see exactly what model you have. Thanks
Sounds like a timer/control unit/selection switch issue. Also, if you set it on other settings does it not operate or still just operate in the gentle cycle?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washing Machine will only complete cycle properly in Gentle Cycle brewskii54 Washer Repair 8 07-26-2012 11:08 AM
washing machine will not cycle bobracko Washer Repair 3 02-06-2011 08:37 AM
Washing machine stops during washing cycle Puddin1719 Washer Repair 4 02-06-2011 07:33 AM
Washing Machine does not go through it cycle. vinnie r Washer Repair 1 01-30-2010 06:49 AM
washing machine stops after agitating cycle, doesn't drain or proceed to next cycle jjd2009 Washer Repair 2 11-13-2009 06:31 AM
