At first the washer would start, the door would lock but when it would spin it would hum and pause. We cleaned out the drain plug and had the same issue so I replaced the door latch, the issue then became as soon as you started the washer it would imediately pause and the door would not lock. I then replaced the control board and the same issue occured. I really can't afford to replace many more parts so if anyone could help it would be greatly appreciated. :confused: :confused: :confused: :confused:
