Discuss
Whirlpool Series 2000 Agitates, but doesn't spin when draining
 in
Washer Repair
I have an old Whirlpool Series 2000 Large Capacity top loading washing machine. My girlfriend was doing laundry yesterday, and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Series 2000 Agitates, but doesn't spin when draining
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-29-2014, 06:30 AM
Junior Member
opmal7 is on a distinguished road
Default Whirlpool Series 2000 Agitates, but doesn't spin when draining
Brand: Whirlpool   Age: More than 10 years
I have an old Whirlpool Series 2000 Large Capacity top loading washing machine. My girlfriend was doing laundry yesterday, and she said went downstairs and found the washer had moved about a foot out of place, and she smelled burnt rubber.
When I got home I ran it through a wash cycle. The washer fills up and agitates just fine. When it drains, it is supposed to drain and spin at the same time. The water will drain, but the basket doesn't spin. It makes a humming noise like the motor is running, but the basket is not spinning.
However, I noticed that if I open the lid and close it again the basket will start spinning. The first time the basket and agitator were spinning at different speeds. I opened and closed the lid again, and they both started spinning at the same speed.
I ran a few more wash cycles and the pattern repeated every time. Fills/agitates ok. Drains, but doesn't spin. If i open and close the lid a few times, the spin starts working.
I took the metal front/sides off the washer, dusted out some cobwebs and inspected everything. Everything appears to look ok, but I didn't take the basket off and look at anything in the motor or gears.
Has anyone seen a similar issue in the past or have any idea what could be wrong?
Edit: The model number is LA5550XPW7
  #2 (permalink)
Old 05-29-2014, 06:33 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Need washer model number.
Eric
  #3 (permalink)
Old 05-29-2014, 06:41 AM
Junior Member
Default
I believe it is LA3300XP
  #4 (permalink)
Old 05-29-2014, 06:51 AM
Expert
APP Volunteer
Default
There are different versions of that model, XPW0 thru XPW4. XPW0 does not have a neutral drain transmission, the rest do, so need to know full model number. Models with neutral drain should drain for 2 minutes without spinning, then motor should pause and restart which causes transmission to shift out of neutral at which point it should start spinning while continuing to drain.
Eric
  #5 (permalink)
Old 05-29-2014, 06:53 AM
Junior Member
Default
I'll have to check on the washer when I get home. I assume there will be a name plate somewhere that should say the full model number?
  #6 (permalink)
Old 05-29-2014, 06:56 AM
Expert
APP Volunteer
Default
Yes, there should be a nameplate with model and serial number.
Eric
  #7 (permalink)
Old 05-29-2014, 12:54 PM
Junior Member
Default
  #8 (permalink)
Old 05-29-2014, 01:24 PM
Expert
APP Volunteer
Default
Ok, that model has a neutral drain transmission which means the washer should drain for 2 minutes without spinning after the agitation cycle. After the 2 minute drain, the motor should pause and then start again. If there is no pause of the motor, then the timer is bad. If there is a pause but washer still won't spin, problem could be clutch or worn drive block. Operate machine in spin mode with cabinet removed (lid switch bypassed). Observe clutch hub. If hub is spinning but tub is not, look above clutch hub into brake housing. If brakes and brake spring are not spinning, then the clutch is slipping or the brake cam driver is not working. If brakes and brake spring are spinning then the tub drive block is probably worn out.
Eric
  #9 (permalink)
Old 05-29-2014, 01:48 PM
Junior Member
Default
How do I bypass the lid switch? If I remove the cabinet, I can't plug in the switch (the wires aren't long enough).
  #10 (permalink)
Old 05-29-2014, 03:18 PM
Expert
APP Volunteer
Default
Make a jumper wire to jump the two wires together (disregard the ground wire). See this video, second switch is similar to yours.
Lid switch bypassing Whirlpool direct drive washer - YouTube
Eric
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore HD 80 Series - Agitates, Pumps but no Spin. wesleyohall Washer Repair 6 01-30-2014 05:32 PM
Kenmore 70 series washer agitates but does not spin tismichael Washer Repair 9 11-16-2013 04:48 PM
Kenmore 90 plus series washer won't spin, barely agitates, will drain & makes noise Maryland Mom Washer Repair 3 08-24-2012 04:32 PM
Kenmore 90 series agitates and drains but won't spin stormspotter Washer Repair 2 02-16-2010 08:46 AM
Kenmore 90 series washer agitates, drains but it Won't SPiN ! selcukbey Washer Repair 3 05-19-2008 11:27 AM
