Discuss
washer will not rinse/ new timer replaced
 in
Washer Repair
Allen If you will insert a putty knife under the control panel where it meets the top near the edges
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer will not rinse/ new timer replaced
  #11 (permalink)
Old 10-27-2009, 01:42 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Allen
If you will insert a putty knife under the control panel where it meets the top near the edges you will be able to release the clips that hold it to the top.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Esate Whirlpool Washer-timer stops once it hits rinse and i manually move to spin joana83 Washer Repair 3 05-17-2009 09:05 AM
Washer goes to rinse cycle then spin back to rinse, stuck in this mod Pat66 Washer Repair 1 05-08-2009 07:44 AM
Replaced washer timer wjt2000 Washer Repair 7 05-01-2009 06:14 AM
Drain pump replaced, now timer stops after wash and will not rinse BeardedDan Washer Repair 1 06-13-2008 11:05 AM
Replaced timer, now what? rollo1960 Washer Repair 2 12-01-2007 06:37 AM
