Washer starts, door locks and nothing happens for several minutes. Then there is a momentary opening of the water solenoid. If you wait fifteen minutes or so the solenoid momentarily opens again but never fills the machine. I downloaded the manual and followed the diagnostics and all tests said the control board was bad so we replaced it. They symptoms were the same with the new unit. The water level switch tested ok. There does not appear to be a magnetic reed switch on the soap drawer on this unit.
