After the cycle finishes and I take out the clothes, it will start filling up with water. Any ideas?
Unplug it after the cycle ends. If it still fills with water then your valve assembly in stuck open and needs to be replaced.
If it stops filling the problem may be in the main control unit. Use the tech notes under the top panel or inside the lower service panel to test and check it.
