MackGoose
#1 Posted : Sunday, May 11, 2014 6:29:29 PM(UTC)
MackGoose
Washer worked fine all weekend. It was washing a load of towels and it just hums now. It sounds like it's coming from the front panel but I'm not positive. It doesn't spin, drain, anything but hum. When I pull the dial out to turn it on that seems looser than normal. Not trying to lead in that direction, but that's all I know right now. I will have to drain it in the morning and then tear it apart. Any suggestions?
MackGoose
#2 Posted : Monday, May 12, 2014 7:34:55 AM(UTC)
MackGoose
Looks like motor burned out. It's stuck and won't spin. Pump was clear and will spin. Motor hums and is permanently locked up.
fairbank56
#3 Posted : Monday, May 12, 2014 12:06:35 PM(UTC)
fairbank56
Groups: Expert
So, the motor shaft will not rotate with motor removed from washer? Very unusual but worth replacing if washer is otherwise in good shape.
Eric
