Hello. I have the 800 series top loader with the floating agitator. A while back, the machine started giving us an uL (Which the manual states is unbalanced load.) After reading bit, I have:
Installed new feet and leveled system Replaced suspension spring rods Cleaned motor shaft and race Removed any debris from the drain pump.
Nothing, still hits me with a uL at 6 minutes remaining on the spin cycle. The only thing I have not replaced is the RPS sensor, as I'm about 100 bucks into this thing already. Any suggestions?
