Washeer drains, and fills but wont spin. Belt is in good shape and motor spins freely. Door latch mechanism was replaced a couple months ago
Use the tech note inside the lower service panel to check out the speed control board. If you want you can replace it on speculation, and if you buy from this site and that does not fix the problem you can return it.
