Has been working fine until yesterday. The power is on. The water is turned on, both hot and cold. The cold water filter has been cleaned; hot water filter did not need it. When the dial to select the washer cycle is turned, it beeps. When the start button is pressed, it does nothing. What do I do to fix it?
