Discuss
Cycles are errratic
 in
Washer Repair
The washer fills, agitates, drains to rinse cycle, fills to rinse, and then sits there. I can fiddle with the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Cycles are errratic
  #1 (permalink)
Old 05-09-2014, 08:24 PM
Junior Member
gregdcwirth is on a distinguished road
Question Cycles are errratic
Model Number: SAWX650JQ0   Brand: Whirlpool   Age: More than 10 years
The washer fills, agitates, drains to rinse cycle, fills to rinse, and then sits there. I can fiddle with the timer dial, turn it around to the beginning, try to get it to agitate again in wash, or get it to drain or agitate in rinse, and nothing happens.
If I am lucky, and the gods are with me, I walk away and come back in an hour, or maybe two, and the cycles have finished the rinse and spin cycle, and I am good to go.
Every wash day is a crap shoot. I never know if the machine will do it's thing or not.
Everything I read suggests the lid switch first, but it sure seems like the timer is confused, tired or otherwise faulty.
I live beyond nowhere. A service call is out of the question, and I don't own an ohmmeter.
Before I moved into this rental, they kept trying to use the machine with a faulty fill valve, so I wonder if something in the timer got burned out....
Any ideas?
Related Models
Whirlpool SAWX650JQ0 WASHER
Whirlpool SAWX650MQ0 AUTOMATIC WASHER
Whirlpool SAWX650MQ2 AUTOMATIC WASHER
Whirlpool SB1000SKN0 BUILT-IN GAS OVEN
Whirlpool SB100PEDB0 24" GAS BUILT-IN OVEN STANDARD CLEAN
Whirlpool SB100PEDB1 24" GAS BUILT-IN STANDARD CLEAN OVEN
Whirlpool SB100PEDB2 24" GAS BUILT-IN-OVEN STANDARD CLEAN
Whirlpool SB100PEDB4 GAS RANGE AND OVEN
Whirlpool SB100PEDB5 24" GAS SLIDE-IN RANGE
Whirlpool SB100PEK1 BUILT-IN GAS OVEN
Whirlpool SB100PER0 Range (gas)*
Whirlpool SB100PES0 Range (gas)*
Whirlpool SB100PES1 Range (gas)*
Whirlpool SB100PES2 Range (gas)*
Whirlpool SB100PES3 Range (gas)*
Whirlpool SB100PES4 GAS RANGES & OVENS
Whirlpool SB100PSK0 BUILT-IN GAS OVEN
Whirlpool SB100PSK1 BUILT-IN GAS OVEN
Whirlpool SB100PSR0 Range (gas)*
Whirlpool SB100PSR1 Range (gas)*
Whirlpool SB130PEDB0 24" GAS BUILT-IN OVEN CONTINUOUS CLEAN
Whirlpool SB130PEDB1 24" GAS BUILT-IN CONTINUOUS CLEAN OVEN
Whirlpool SB130PEDB2 24" GAS BUILT-IN-OVEN CONTINUOUS CLEAN
Whirlpool SB130PEK0 BUILT-IN GAS OVEN
Whirlpool SB130PER1 Range (gas)*
Whirlpool SB130PER2 Range (gas)*
Whirlpool SB130PER3 Range (gas)*
Whirlpool SB130PER4 GAS BUILT-IN OVEN
Whirlpool SB130PER5 24" GAS BUILT-IN OVEN ELECTRONIC IGNITION CONTINUOUS CLEAN OVEN
Whirlpool SB130PERW0 Range (gas)*
Whirlpool SB130PSK0 BUILT-IN GAS OVEN
Whirlpool SB160PEDB0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB2 24" BUILT-IN-OVEN
Whirlpool SB160PEDB4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ2 24" BUILT-IN-OVEN
Whirlpool SB160PEDQ4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEEB1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEB2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEB5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEB6 BUILT-IN GAS OVEN
Whirlpool SB160PEEB7 BUILT-IN GAS OVEN
Whirlpool SB160PEEB8 BUILT-IN GAS OVEN
Whirlpool SB160PEEB9 BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEQ2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEQ6 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ7 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ8 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ9 BUILT-IN OVEN, GAS
Whirlpool SB160PEXB0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ1 BUILT IN GAS OVEN
Amana SB21VE REF - SXS/I&W
Amana SB21VPSE REF - SXS/I&W
Amana SB21VW REF - SXS/I&W
Thermador SB2B
Amana SB520K REF - SXS/I&W
Amana SB520SW REF - SXS/I&W
Amana SB520TW REF - SXS/I&W
Amana SBC24FX0 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FX5 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FXOW RANGE - ELECTRIC STD DELAWARE
Amana SBC26CK RANGE - ELECTRIC STD DELAWARE
Amana SBD20H REF - SXS/I&W
Amana SBD20J Ref - SXS/I&W
Amana SBD20K REF - SXS/I&W
Amana SBD20M REF - SXS/I&W
Amana SBD20MW REF - SXS/I&W
Amana SBD20NE REF - SXS/I&W
Amana SBD20NW REF - SXS/I&W
Amana SBD20Q2E REF - SXS/I&W
Amana SBD20Q2W REF - SXS/I&W
Amana SBD20S4E REF - SXS/I&W
Amana SBD20S4L REF - SXS/I&W
Amana SBD20S4W REF - SXS/I&W
Amana SBD20TPE REF - SXS/I&W
Amana SBD20TPL REF - SXS/I&W
Amana SBD20TPSW REF - SXS/I&W
Amana SBD20TPW REF - SXS/I&W
Amana SBD21VE REF - SXS/I&W
Amana SBD21VL REF - SXS/I&W
Amana SBD21VPE REF - SXS/I&W
Amana SBD21VPSE REF - SXS/I&W
Amana SBD21VW REF - SXS/I&W
Amana SBD522VE REF - SXS/I&W
Amana SBDE20S4SW REF - SXS/I&W
Amana SBDE20TPE REF - SXS/I&W
Amana SBDE20TPW REF - SXS/I&W
Amana SBDE21VPE REF - SXS/I&W
Amana SBDE21VPSE REF - SXS/I&W
Amana SBDE520K REF - SXS/I&W
Amana SBDE520M REF - SXS/I&W
Amana SBDE520NW REF - SXS/I&W
Amana SBDE520SW REF - SXS/I&W
Amana SBDE520TW REF - SXS/I&W
  #2 (permalink)
Old 05-12-2014, 07:12 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
It is unlikely to be the lid switch because it goes through the full wash cycle. You can check it without a meter by by-passing it, see the videos on changing out the lid switch for how to open it, then just stick a small solid core wire in the two non green holes in the lid switch connector coming from the console.
This sounds more like a timer problem. If the lid switch checks out I would replace the timer. You can buy from this site and if the timer is not the problem you can return it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer makes grinding noise on wash and rinse cycles. Spin cycles are fine Debbie Foster Washer Repair 3 09-30-2013 01:12 PM
spins 3 cycles one way, 3 cycles the other way, then will not spin after that huntly Washer Repair 2 09-26-2011 04:10 AM
Fan cycles on and off Rickfromchurch Refrigerator & Freezer Repair 1 08-25-2010 03:25 AM
GE Wont advance cycles... Have to manually turn knob to advance cycles at 2 points nickf829 Washer Repair 1 12-20-2009 04:43 PM
will not go through the cycles clamman Dishwasher Repair 5 12-11-2009 06:35 AM
