Discuss
Delayed start after water filled
 in
Washer Repair
Normal Wash cycle..start filled with water and won't start the agitation until about 2-3 mins. end of the wash cycle,pause
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Delayed start after water filled
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-02-2014, 09:41 AM
Junior Member
Remegia is on a distinguished road
Default Delayed start after water filled
Model Number: SAWS800JQ!   Brand: Whirlpool   Age: 5 - 10 years
Normal Wash cycle..start filled with water and won't start the agitation until about 2-3 mins. end of the wash cycle,pause then water drain a little bit and stops through the end of the normal wash cycle. When changes to Permanent and Handwash Cycle ,won't worked but if I put on the Delicate Cycle, finish the cycle normally. Maybe you can have some suggestion.
Related Models
Whirlpool SAWS800JQ0 WASHER
Whirlpool SAWS800JQ1 WASHER - DIRECT DRIVE
Whirlpool SAWS800JQ2 WASHER
Whirlpool SAWS800MQ0 AUTOMATIC WASHER
Whirlpool SAWS900HQ0 WASHER
Whirlpool SAWS900JQ0 WASHER - DIRECT DRIVE
Whirlpool SAWS900MQ0 AUTOMATIC WASHER
Whirlpool SAWX650JQ0 WASHER
Whirlpool SAWX650MQ0 AUTOMATIC WASHER
Whirlpool SAWX650MQ2 AUTOMATIC WASHER
Whirlpool SB1000SKN0 BUILT-IN GAS OVEN
Whirlpool SB100PEDB0 24" GAS BUILT-IN OVEN STANDARD CLEAN
Whirlpool SB100PEDB1 24" GAS BUILT-IN STANDARD CLEAN OVEN
Whirlpool SB100PEDB2 24" GAS BUILT-IN-OVEN STANDARD CLEAN
Whirlpool SB100PEDB4 GAS RANGE AND OVEN
Whirlpool SB100PEDB5 24" GAS SLIDE-IN RANGE
Whirlpool SB100PEK1 BUILT-IN GAS OVEN
Whirlpool SB100PER0 Range (gas)*
Whirlpool SB100PES0 Range (gas)*
Whirlpool SB100PES1 Range (gas)*
Whirlpool SB100PES2 Range (gas)*
Whirlpool SB100PES3 Range (gas)*
Whirlpool SB100PES4 GAS RANGES & OVENS
Whirlpool SB100PSK0 BUILT-IN GAS OVEN
Whirlpool SB100PSK1 BUILT-IN GAS OVEN
Whirlpool SB100PSR0 Range (gas)*
Whirlpool SB100PSR1 Range (gas)*
Whirlpool SB130PEDB0 24" GAS BUILT-IN OVEN CONTINUOUS CLEAN
Whirlpool SB130PEDB1 24" GAS BUILT-IN CONTINUOUS CLEAN OVEN
Whirlpool SB130PEDB2 24" GAS BUILT-IN-OVEN CONTINUOUS CLEAN
Whirlpool SB130PEK0 BUILT-IN GAS OVEN
Whirlpool SB130PER1 Range (gas)*
Whirlpool SB130PER2 Range (gas)*
Whirlpool SB130PER3 Range (gas)*
Whirlpool SB130PER4 GAS BUILT-IN OVEN
Whirlpool SB130PER5 24" GAS BUILT-IN OVEN ELECTRONIC IGNITION CONTINUOUS CLEAN OVEN
Whirlpool SB130PERW0 Range (gas)*
Whirlpool SB130PSK0 BUILT-IN GAS OVEN
Whirlpool SB160PEDB0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB2 24" BUILT-IN-OVEN
Whirlpool SB160PEDB4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ2 24" BUILT-IN-OVEN
Whirlpool SB160PEDQ4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEEB1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEB2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEB5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEB6 BUILT-IN GAS OVEN
Whirlpool SB160PEEB7 BUILT-IN GAS OVEN
Whirlpool SB160PEEB8 BUILT-IN GAS OVEN
Whirlpool SB160PEEB9 BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEQ2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEQ6 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ7 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ8 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ9 BUILT-IN OVEN, GAS
Whirlpool SB160PEXB0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ1 BUILT IN GAS OVEN
Amana SB21VE REF - SXS/I&W
Amana SB21VPSE REF - SXS/I&W
Amana SB21VW REF - SXS/I&W
Thermador SB2B
Amana SB520K REF - SXS/I&W
Amana SB520SW REF - SXS/I&W
Amana SB520TW REF - SXS/I&W
Amana SBC24FX0 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FX5 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FXOW RANGE - ELECTRIC STD DELAWARE
Amana SBC26CK RANGE - ELECTRIC STD DELAWARE
Amana SBD20H REF - SXS/I&W
Amana SBD20J Ref - SXS/I&W
Amana SBD20K REF - SXS/I&W
Amana SBD20M REF - SXS/I&W
Amana SBD20MW REF - SXS/I&W
Amana SBD20NE REF - SXS/I&W
Amana SBD20NW REF - SXS/I&W
Amana SBD20Q2E REF - SXS/I&W
Amana SBD20Q2W REF - SXS/I&W
Amana SBD20S4E REF - SXS/I&W
Amana SBD20S4L REF - SXS/I&W
Amana SBD20S4W REF - SXS/I&W
Amana SBD20TPE REF - SXS/I&W
Amana SBD20TPL REF - SXS/I&W
Amana SBD20TPSW REF - SXS/I&W
Amana SBD20TPW REF - SXS/I&W
Amana SBD21VE REF - SXS/I&W
Amana SBD21VL REF - SXS/I&W
Amana SBD21VPE REF - SXS/I&W
Amana SBD21VPSE REF - SXS/I&W
Amana SBD21VW REF - SXS/I&W
Amana SBD522VE REF - SXS/I&W
Amana SBDE20S4SW REF - SXS/I&W
Amana SBDE20TPE REF - SXS/I&W
Amana SBDE20TPW REF - SXS/I&W
Amana SBDE21VPE REF - SXS/I&W
Amana SBDE21VPSE REF - SXS/I&W
  #2 (permalink)
Old 05-09-2014, 12:34 PM
Junior Member
araldrich is on a distinguished road
Default
I am having the same problem with an Admiral direct drive washer. Always the spin cycle. Made by Maytag but masquerades as a number of bottom line machines. (whirlpool, sears etc) Can buy a brand new one for $350, but won't buy this brand or its cousins ever again. Assembled in Mexico from Chinese parts.
Ordered and installed a new control board. Solved part of the problem, but still won’t spin past a certain speed then shuts down. Clothes are always wet.
Now I have ordered a new cycle timer and plan to bypass the lid switch with a jumper. This $350 washer has already cost me nearly $200 and its only a year and six months old.
  #3 (permalink)
Old 05-11-2014, 01:19 PM
Junior Member
Default
Maybe still on manufacturer's warranty. I replace the timer and works great.Dis asemble all the inner parts,inner tub ,agitator, hoses,wirings etc... well after putting back all.I have a good as new washer and anothe 5- 10 yrs. Thanks to repair forum
  #4 (permalink)
Old 05-12-2014, 01:09 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
What is the model number of the Admiral washer?
Eric
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water fill is delayed and erratic bdlaur Washer Repair 7 03-31-2012 02:16 PM
Water fill is delayed, must wait to have water in rinse cycle sewsmack Washer Repair 0 10-19-2010 02:45 PM
delayed water start wstickles Dishwasher Repair 3 12-22-2008 04:49 PM
Ice & Water turn off delayed 3-5 sec rudylyon57 Refrigerator & Freezer Repair 0 02-12-2008 04:23 PM
Water entering during delayed start Greg Dishwasher Repair 0 08-14-2007 09:33 AM
