My front load Frigidaire washer will not complete a wash goes through until final spin then gives error code E20. I cleaned the drain hoses thinking maybe it wouldn't drain so it wouldn't spin but that has not worked.
The speed or motor control board frequently fails on these models.
See if you can locate a tech sheet inside the machine after you take off the lower access panel. Then clean out the pump area and try to go through the diagnostics in the sheet.
